Squeezebox PS construction questions...
0 Members and 1 Guest are viewing this topic. Read 6231 times.
  • Speakers....What Speakers ?
Re: Squeezebox PS construction questions...
« Reply #20 on: 23 Jun 2007, 07:02 am »
So....which one works better ? :lol:
Hey Dude,
  Your PS sure looks like mine. Are they twin brothers???
That is a tough question.  :lol:
PS Shootout.... :lol:
It would be cool if you both could compare you units.... 8)
jonwb
« Reply #21 on: 23 Jun 2007, 07:12 am »
Well... w/ a little coaching (and more $$ of course) I could build my second Condor based PS more like F-100's.  Then I could see if its better than the stock Condor, or better enough to be worth twisting all those little yellow wires  :)
F-100 is that the same Condor unit I used?
F-100
« Reply #22 on: 23 Jun 2007, 07:20 am »
Mine is a Power-One which is similar design to your Condor.
BTW, my unit is also running a bit warm so just to be on the safe side, I drilled some ventilated holes on both sides of the enclosure.
crooner
« Reply #23 on: 23 Jun 2007, 02:27 pm »
Crooner,
  That is some serious PS you got there. What are those 3 black things on the right side of the picture. Are they ferrite beads?? How much improvement do you notice on this one over your old Power-One PS?
Yeah, they are ferrite beads to suppress EMI radiated from the big power transformer. I also used Stillpoints ERS sheets liberally inside the chassis for the same purpose.
Basically, the improvement I got was a smoother less "electronic" sound. More organic if you will. I built this one for sheer fun, to test how far one could go with a Squeezebox PS. But you can certainly get 80%, if not more, of the benefits with the smaller 3A Power One supply, IMO.
BTW, mine runs super cool for a 12A supply!
« Last Edit: 24 Jun 2007, 07:06 am by crooner »
