D200's and Quad ESL 57's
dom_
« on: 10 Jun 2007, 08:01 pm »
Are the d200's able to drive 57's?
If yes has any done this or heard a system like this?
Many Thanks
Charles Calkins
Re: D200's and Quad ESL 57's
« Reply #1 on: 10 Jun 2007, 08:10 pm »
My bud and I hooked up my D-200's to his Martin Logan CSL speakers. No problem driving the crap out of them. M.L. similar to the quads???
                                                  Cheers
                                                  Charlie
randytsuch
« Reply #2 on: 10 Jun 2007, 10:52 pm »
I would be careful, looks like they have too much power.
I owned 57's for many years, and I don't think you want to put more then 50 watts into them.  You can burn the panels if you feed them too much power.
I drove them for many years with a stock Dynaco ST-70.  It did a good job, but at one time, I auditioned a old Eico integrated, and they sounded great with that guy.  Only reason I did not buy it was I could not figure out at the time how to hook up a sub to it (I could now, but that was a while ago).  I don't the the 57's anymore, but that was a sweat combination.
Randy
CIAudio
« Reply #3 on: 11 Jun 2007, 05:34 am »
Shouldn't be any problem...we have a few customers using them with Quad 63's (similar impedance curve).
dom_
« Reply #4 on: 11 Jun 2007, 05:37 pm »
Brilliant thank you.
randytsuch:
my 57's have a protection board fitted.
randytsuch
« Reply #5 on: 11 Jun 2007, 08:50 pm »
Removed my response.
Just saw your response about a protection board, which I assume will protect from too much power.
Randy
