0 Members and 1 Guest are viewing this topic. Read 3922 times.
I, am doing a 20 cap upgrade to the signal path nex't...all with BG caps and after that,I am thinking Superclock2 and possible opamp upgrades.The rectifiers are on the list also,but I plan on doing the mods one at a time to see which mods are best sonically.The goal is 2.5-3k cd only player sonics whith the bonus of much better sacd sonics and even HT sonics in one box.If 600.00 in mods is enough to reach this goal, it remains to be seen,or rather.. heard.
Vinnie, I got the cap and most all my upgrade parts from www.referenceaudiomods.comThey are touting the Jensen four pole cap as even better than the BG power caps when used on a ps.I am sure they have a BG power cap that is close to your Pioneers.
Vinnie- I also have a 45A and installed the BG VK 150uf/350vdc cap in the power supply.It take some adjustment of the nearby part parts, but it can be installed in the stock holes.Upgraded some other caps in the power supply and the main board.The key targets are the C350/360 - 47uf/16vdc coupling caps in the 2 channel output, Replaced those with BG FKs.Also, put in a IEC, replaced the AC bridge reticfiers with GS Ultrafast 8.0A units and dampen the chassis with Blackhole pad.Good improvement, but as stated the BGs take a while to break-in.
