teflon tube socket for the GK-1?
0 Members and 1 Guest are viewing this topic. Read 2016 times.
kyrill
« on: 5 Jun 2007, 02:48 pm »
hi ppl/Hugh
Is there a teflon tube socket for the GK-i among them? I cannot find it
http://www2.117.ne.jp/~y-s/parts-socket-e.html
andyr
Re: teflon tube socket for the GK-1?
« Reply #1 on: 5 Jun 2007, 09:07 pm »
hi ppl/Hugh
Hi kyrill,
I used Japanese, gold-plated-pin, porcelain tube sockets in my GK-1 ... bought from Michael Percy.
Andy
kyrill
« Reply #2 on: 5 Jun 2007, 09:52 pm »
Hi An
Porcelain is "classique" Teflon ( according to my intuition God knows why) may have better damping characteristics and so better help the tube to create a black void, a deep silent dimension underneath the music while  carrying it
also have much better dielectric constant
« Last Edit: 17 Jul 2008, 11:22 am by kyrill »
AKSA
« Reply #3 on: 5 Jun 2007, 10:43 pm »
Kyrill,
In my experience, the quality of the socket makes very little sonic difference, though the resistivity of the material, particularly around the grid termination, is important.
The choice of tube is important, with many reporting the highly expensive gold pin Siemens 7308 amongst the best.  But the 6ES8/CV5331 is variable mu and slightly more euphonic.  It does depend on whether you want the organic sound or the ultra clean sound;  preferences do vary.
As for damping, I'd suggest a springly plastic damper or Pearl tube cooler as these work directly on the glass envelope, just where you want it......
Hope this helps,
Hugh
kyrill
« Reply #4 on: 5 Jun 2007, 11:17 pm »
yes
it helps
thx
