My speakers (EgglestonWorks Fontaines - TMM - M's are Morel 6.5" polys) do not delve too deeply: -3dB @ 55Hz. I have a Titan sub, dialed to its lowest setting, resulting in a very satisfying full-enough for me-range sound (within +-3dB to 25Hz, where it is -4dB, and -7dB at 20Hz). Would adding the high-pass filters relieve my amp (Van Alstine Fet Valve Ultra 550) enough to warrant using? If so, which (65Hz or 85Hz)? And would their use degrade the sound quality from my mains in any way?
Mike - Insertion loss requires increasing the mains level? Does this mean that my amp will be working even harder than prior to the insertion of the filters?
Anyone out there use the high-pass filters from ACI?What is your experience with them?I was told that filters such as these (not ACI's specifically) may mess up my highs and/or mids, constrict the soundstage width/depth, and likely impart their own signature into the sound, which would not be desireable.
Not to hyjack the thread, but I have a similar question & either I could start a new & very similar thread or add to the knowledge base here...so...Mike,I have a set of full range(36Hz-18kHz) Snell Type A's and I recently added a Titan LEII. Sounds great so far(crossing over at around 40Hz), but I have run across your comments about the high pass filter being a step in the right direction. You offer the HP filters at 65 & 85Hz. The 65 seems a bit high for my speakers...would they be appropriate? I have around 350 watts/channel going into the Type A's (86dB sensitivty) so I'm not hurting for power...is the HP option still advisable? It might be worth locating the article you wrote & posting it in your web site's FAQ section as this topic probably comes up frequently (I would think).
Dateline Atlanta ... "Slowest audiofile on the planet (me) finally installs ACI 65Hz in-line (RCA) filters - amazing results ensue" ...I originally ordered the 85Hz filters, tried them out very briefly and felt I wanted to allow my mains to run slightly lower freqs so my sub would not have to run much, if at all, above 80Hz (the freq limit of non-direction). So I traded my 85s for another member's 65s, allowed them to collect just the right amount of dust and threw them in the other day.Here is the data collected using my Radio Shack SPL meter (corrected) at my listening seat without and with the 65Hz in-line (RCA) filters playing ACI Sub Setup CD (warble frequencies) through my mains (Fontaines) with my subwoofer OFF, calibrated at 1kHz (and verified at 250Hz) to 80dB. (My room creates a suckout of -6dB at 55Hz and 60Hz when playing mains AND sub together regardless of the filters.) Mains only Mains only No Filters w/FiltersHz dB dB-- -------- ------22.5 57 -25 59 -27.5 62 -30 64 -32.5 67 -35 68 -37.7 68 -40 67 6145 67 6250 69 6455 70 6660 70 6765 70 6670 77 6775 80 7580 80 7985 82 8090 82 82As you can see, the filters do their job in keeping the mains from attempting to produce very low freqs. The sound with the filters installed and sub ON (set to lowest crossover point) has greatly increased clarity. Better imaging and soundstage, and I am also able to increase the volume greater than before with NO distortion. An absolutely amazing improvement for $30!! A belated THANK YOU to MIKE D!
...The sound with the filters installed and sub ON (set to lowest crossover point) has greatly increased clarity...
