0 Members and 1 Guest are viewing this topic. Read 4083 times.
Do you have any experience with the Eastern Electric BBA which is referenced in the review? What do you think of it in terms of it's reported purpose of electrical matching of components?
Currently I'm in a holding pattern, just using an Oppo 970, and the sound is a bit thin (some lack of deep bass with a mid-treble emphasis) so was wondering what the next step should be (VDA-2, DEQ, buffer, or a whole different source). Cost and simplicity are important factors in the decision.
QuoteCurrently I'm in a holding pattern, just using an Oppo 970, and the sound is a bit thin (some lack of deep bass with a mid-treble emphasis) so was wondering what the next step should be (VDA-2, DEQ, buffer, or a whole different source). Cost and simplicity are important factors in the decision.The VDA-2 has a really wonderful sounding presentation. Dynamic and very balanced across the frequencies. It doesn't call attention to itself in any way, which is actually a very good thing if you think about it. Bass response got better when I added the optional power supply. I don't know your budget but I'd definitely recommend getting both these components over time as you can afford them. It's what I did and am ecstatic just listening to music and not thinking/worrying about components.
Quote from: Grover on 6 Jun 2007, 10:45 pmQuoteCurrently I'm in a holding pattern, just using an Oppo 970, and the sound is a bit thin (some lack of deep bass with a mid-treble emphasis) so was wondering what the next step should be (VDA-2, DEQ, buffer, or a whole different source). Cost and simplicity are important factors in the decision.The VDA-2 has a really wonderful sounding presentation. Dynamic and very balanced across the frequencies. It doesn't call attention to itself in any way, which is actually a very good thing if you think about it. Bass response got better when I added the optional power supply. I don't know your budget but I'd definitely recommend getting both these components over time as you can afford them. It's what I did and am ecstatic just listening to music and not thinking/worrying about components.The VDA-2 + VAC1 is indeed wonderful sounding and I'm enjoying every minute of it ever since I received my unit 2 weeks back.. I'm not without worry though.The only worry is that the rest of my components (Marantz DVD player, Audionote M-zero, DIY Hypex UCD180AD amp, JMlab Cobalt 816s) may restrict the VDA2 from giving out its full potential.
In a system like the one in the review, he's basically telling you he doesn't like the sound of his source component by itself as much as with the BBA. Being that D-200's have 100k input impedance, most any source can drive them through a 10k passive, so I suspect the tube flavor/harmonic distortion of the BBA are what he liked.
