Q. on cables for Force XL
0 Members and 1 Guest are viewing this topic. Read 1425 times.
Alwayswantmore
« on: 28 May 2007, 09:53 pm »
Mike, temporarily I'm in a small rental space. Your cables have double shielding, so will it be OK to do a tight coil of the excess cable? [I say this because general wisdome is to not coil cables.] Thanks, Kent
Mike Dzurko
Re: Q. on cables for Force XL
« Reply #1 on: 29 May 2007, 08:25 pm »
Coiling the cables will increase inductance which should only effect the upper end of the spectrum . . . . not the low end. Shouldn't be a problem . . .
Alwayswantmore
« Reply #2 on: 29 May 2007, 10:10 pm »
Thanks.
