0 Members and 1 Guest are viewing this topic. Read 10515 times.
It has been a while since this thread was active but I do wonder about the actual comparative sound qualities of the Sooloos compared to the SB3 or a Transport. Anyone have any helpful information on this - excluding any references to cost? I had a chance to play with the Sooloos today and it was VERY fun and had VERY fast integration/response. Just not sure of the sound quality compared to the other choices.Thanks,James
With the amount of storage available don't understand the need for any file format besides wav or aif.
Actually, the weak spot of the sooloos is the DAC. It's probably not a ton better than a squeezebox, but I use a Wadia 521 with mine, so it's no big.Just met with the sooloos guys the other day and they have a new bare bones model that you can configure yourself that will be around 3000 bucks and still feature their zooty interface. We'll have a report as soon as we can get our hands on one....
Jeff,You said - "Actually, the weak spot of the sooloos is the DAC. It's probably not a ton better than a squeezebox, but I use a Wadia 521 with mine, so it's no big."If you spent 12K on the Sooloos, wouldn't you expect that you wouldn't need to use the Wadia 521? It seems you should have gotten a better DAC in the unit for that kind of money.just my thought.Chuck
