Cornet2 tube and voltage questions
ecir38
Re: Cornet2 tube and voltage questions
« Reply #20 on: 30 Oct 2007, 06:20 pm »
I used some hot glue to help support them to the pcb too being the only thing holding them in place is just the solder for the one pin. I also found that by dabbing some oil on the thread of the screws helped being they were pretty hard to screw in and out.
