0 Members and 1 Guest are viewing this topic. Read 36393 times.
Hi el'Ol,Yes, looks good, but as you say, can graphs be compared from model to model? It does have a rising peak at 2000Hz, which the Precision Devices seem to avoid?I'd be interested to know the comparative prices.David
Hi el'Ol,I'd never heard of them, but Precision Devices sure do seem to make some magnificent drivers.I'm not qualified in the slightest to make any judgement on the matter, but maybe I can offer suggestions as to which might work better with my design technique.I'd rule out any with an Fs higher than 30Hz (especially if you're going to the trouble of 18" drivers)- that seems to knock three off the list.There are two that have highish Qts- they might be too high to compensate.That seems to leave the PD184, PD186 and the PD1850.The response graphs don't seem to be represented in an absolutely equivalent way. e.g.the PD1850 graph stops- what is the high freq. like? Should you take a chance?That leaves for me the PD184 or the PD186.PD186 is better made, with better parameters in other respects.It's probably one of the dearer ones??I emphasise again that I am totally unqualified to judge a manufacturer's products that I have never seen or heard.So that's it for what it's worth.David
So this (although I don't understand why and how- if indeed Basta is right) would explain the empirical results.
To answer your question, that's why I go for middle Qt drivers, to avoid the resonant peak, and to give room to fine tune the inductor impedance and dc resistance.David
What about taking a high-Qts speaker and flattening out the impedance peak with a series notch filter?
How is that going to get around the high Qts driver's inherent inability to stop itself from flopping around at resonance? Isn't impedance taming just for the amp's benefit?
I found a high-Qts 15" driver from Selenium that looks even better than the Hemp.http://www.seleniumloudspeakers.com/site2004/catalogo/pdf/wooferpw3_15pw3_15pw3-slf_new.pdfWhy can`t I find low Qts drivers with equally good top end?
