0 Members and 1 Guest are viewing this topic. Read 8661 times.
I don't know if this is the right thread to ask this question, if not I apologize. I have a rebuilt Eico preamplifier which line stage consists of two 12AX7 tubes. I have two questions,1. Can I drop in two 12AT7's?2. What would I gain or lose? Thank You
Hi gentlemen, I have to respectfully disagree on the 12AT7 being more linear, esp against the 12AX7, 12AU7, and even the 6dj8/6922/E88cc tubes in lower signal service. In my measurements, and inspecting the curves, years ago, the 12AT7 had very high distortion. I found it very unacceptable.
Hi gentlemen, I have to respectfully disagree on the 12AT7 being more linear, esp against the 12AX7, 12AU7, and even the 6dj8/6922/E88cc tubes in lower signal service. In my measurements, and inspecting the curves, years ago, the 12AT7 had very high distortion. I found it very unacceptable.Here is a picture of the curves. Notice the odd spacing.http://www.mif.pg.gda.pl/homepages/frank/sheets/087/1/12AT7WA.pdfNow a typical 6dj8 (not JJ curves which is a more linear tube).http://www.mclink.it/com/audiomatica/tubes/6dj8.htmNow a typical 6sn7wtb tube.http://www.nj7p.org/Tube4.php?tube=6SN7GTBNotice the 12AT7 curves are no where near the other tubes. (For newbies, check the spacing between the lines. The spacing varies.)At lower signal levels (say 5 volts rms) the JJ E88cc (european number) is much much lower in distortion than any NOS 6dj8/12AX7, 12AU7 and 6SN7 tube made. Anyway, if JJ did to the 12AT7 what they did to their E88cc, it is probably the lowest distortion 12AT7 made in any era.Take care.
Thanks SteveI already (ordered) JJ12at7 to try in place of my EH12ax7s (input tubes).Unless I am confused Bill (Response Audio) said this was an OK move and he has been modding Jolidas for many years. I believe he prefers them in that gear over the 12ax7,I do not know if he has heard the JJ 12ax7, the JJ stuff is getting many good comments from people.I also ordered JJ12at7 to try in place of my EH12at7s (driver tubes).Considering the price & praise of the JJ tubes and your recommend on keeping the (input tubes) as 12ax7s, I am going to order 2 matched JJ 12ax7. Then I can compare with my ear, its cheap enough.Thanks for jumping in, I do appreciate your feedback, it will be well worth my 30. to try the JJ12ax7 also. My only reference in this part of my amp was Chinese tubes and the EH stomped them, I am getting the impression the EH are detailed but not necessarily graceful. I have restrained high hopes for the JJ 12ax7s and the 12at7s.
You can use variations of the 12AX7 for the input tubes right down to the 12AU7. The problem here is that the amps circuit is not optomized for the 12AU7 and causes increased distortion when pushed too hard.
The circuit for the JD1000 is the same as the 302/502 amps with only additional circuitry for the extra output tubes. I do prefer the 12AU7 over the AX7. This is why I redesigned the circuit of our Bella Extreme 3205 MK II amplifiers (based on the Jolida "A" series 302/502 chassis) and optomized it for the 12AU7. While you can sometimes use the 12AU7 in place of the AX7, you CANNOT substitute the AX7 for the AU7 due to differences in opperating points.
I do run one of my original 3205 amps, before the MK II circuit change, with 12AU7 input tubes as I still prefer the sound.
