0 Members and 1 Guest are viewing this topic. Read 8651 times.
Quotenormal confiquration is:(2) 12at7s for pre amp(2) 12ax7s for power drivers. Sorry dude, you have this backwards. The 12AX7 tubes are the input tubes (two center tubes) while the 12AT7s are the driver/splitter tubes. (outside tubes).
If you have these reversed, this could cause damage to the amp's circuitry if left in place too long as the 12AX7 is too "hot" to be used as a driver.
I hate doing it so I'm sure its not at optimum, I probably need to check it more often.
QuoteI hate doing it so I'm sure its not at optimum, I probably need to check it more often. Just curious when you biased the tubes last? Did you replace any tubes and not bias all of them? Tubes that are biased higher than their proper setting can also produce noise in the system. I know it is a bit more difficult in the JD1000 but I would definitely check them periodically. Whenever you install new tubes, you should always turn the bias pots all the way down before installing the tubes. You never know what the new tubes' specifications are. Then go through and re bias all the power tubes. I would recommend a bias between 35mV-37mV.
Wow, what a beautiful amp. Nice clean design. Looks like you have individual bias pots for each tube I like all those tube dampers too. I gotta try that on mine sometime.
You pretend to be a neophyte and then find out you are a seasoned tweeker!
I don't have particularly good vibration isolation rack. WEEZ recommended the Mapleshade rubber/cork isolators for TTs, I might try some of those sometime too.
