Finally finished my Squeezebox PSU
0 Members and 1 Guest are viewing this topic. Read 1669 times.
JoshK
« on: 14 May 2007, 02:21 am »
Well, I don't know how many months I have had this PSU sitting on my bench 80% finished.   I finally got the case all built (experimented by using MDF and hammerall textured paint) and put everything together.  I built a little Felix right into the PSU, 'cept the Felix CMC makes a faint buzzing sound, but nothing you can hear from a few feet away.
Anyway, its too early to tell, there are the classic signs of needing breakin like exploding bass and closed in highs, but I don't think I've ever heard my speakers dissapear quite like this before.
F-100
Re: Finally finished my Squeezebox PSU
« Reply #1 on: 14 May 2007, 03:51 am »
Got any pictures to show us?  :)
JoshK
« Reply #2 on: 14 May 2007, 05:42 pm »
I do, but I didn't have a chance last night to up any.   I will shortly.
P.S.  Basically I followed the design that is in a few other threads on this forum... bridge > cap > reg > cap, with things like 47,000uf Jensen 4poles, IXYS bridge and a LT1085 (also have app note for setting voltage).
Either my DMM is slightly off or I didn't set the Reg spot on because I measured 4.77V output.  Close enough to work, but still irks me a bit.
CornellAlum
« Reply #3 on: 14 May 2007, 06:16 pm »
When I built mine, I started with cheap parts and moved up the chain once I figured out what I was doing.  My first go around I used a regulator from the shack which was putting out 4.98V and it wouldn't power the SB3 at all.  Switched that out for an lt1086-5 (the fixed voltage one), and it puts out a solid 5.0 and worked like a charm.  The point of this is...your VT might not be working.
JoshK
« Reply #4 on: 14 May 2007, 06:42 pm »
My guess is that my resistors aren't so precision and need some trimming.  I plan to play with it some more, as I haven't even put the top back on.  I was just happy to get it to work after months and months of sitting there waiting to be finished.
The reg chip I mounted with a 3 pin pheonix style connector, so it can easily be swapped out for another chip or I can change reg circuit entirely.
crooner
« Reply #5 on: 14 May 2007, 10:04 pm »
Love to see the pics!
I've just finished upgrading mine with IXYS FREDs and a Auricap film bypass of the filter caps. I also added Stillpoints ERS cloth to the cabinet sides and bottom, plus plenty of ferrite snap-in cores.
tanchiro58
« Reply #6 on: 15 May 2007, 12:14 am »
Josh,
There is a plenty of reservoir cap (47,000uF) but how do you connect with 4 poles? I got a Jensen 15,000uF/500V with 4 poles but I got stuck that how would I connect the poles to use with 15,000uF? Thanks in advance.
Tan
JoshK
« Reply #7 on: 15 May 2007, 12:20 am »
think of it like 2 +,s and 2 -,s in parrallel.  almost like two caps in parrallel.  There is an input +, an input -, an output + and an output -.  Input is cap 1, output is cap 2.  Just dont' put a wire between the inputs and output and it is like two caps in parrallel.
