0 Members and 1 Guest are viewing this topic. Read 4595 times.
Hi All,I'm just starting to explore the whole music server idea, and have been playing with it a bit. I want to make sure everything works right before I commit fully to it. I have not yet purchased extra hard drives, an outboard USB DAC or anything, as I'm still trying to grasp file structures at the present time. If I can get the library function working correctly, then I will proceed.I've been using EAC to copy a dozen or so discs to my hard drive in my laptop. I did follow all of the advice in the sticky. Then, I use Windows Media Player 9.0 to search for album artwork. Then I want to use Foobar 2000 as my interface, but when it pulls up the album, the track order is all wrong. Also, the album artwork is missing. I'd like the GUI to look and sort like it does in Windows Media Player, but it doesn't.Do I even need Foobar 2000? Everyone says iTunes won't work, but iTunes seems to play the FLAC files I compressed as a test.What am I doing wrong? Thanks,Nels
I have things working better now. Almost there in fact.I still have a problem with correct CD order when converting. The correct order shows in Windows Media Player. FLAC and Foobar 2000 put the tracks in abphabetical order. Any ideas?
You may have tried this already but your tagging commands in EAC have an order to them. In other words, if you want the track number to be read first by Foobar, you need to move it up in the command line.
