HD format key hacked - when will the digital revolution become too much?
0 Members and 1 Guest are viewing this topic. Read 3984 times.
jqp
This is the commercial product for HD formats
Code: [Select]
AnyDVD HD™
AnyDVD HD comes with same functionality as AnyDVD,
but with additional features for full HD-DVD (High Definition DVD)
and Blu-Ray support, including decryption of HD-DVD & Blu-Ray movie discs.
Allows you to watch movies over a digital display connection,
without HDCP compliant graphics card and HDCP compliant display.
No need to buy an expensive monitor. Sweet!
Playback your discs on your PC with PowerDVD Ultra,
which otherwise do not run (titles released by Studio Canal,
The Weinstein Company, Kinowelt, Optimum Releasing).
AnyDVD HD is the "must have" utility for the serious home theater
enthusiast using a media center / home theater PC.
Another amazing feature of AnyDVD HD is "magic file replacement ™".
Remaster any commercial movie disc using simple XML scripts. These scripts
will "magically" replace the files on the physical disc. You can customize discs as
you like without even making a copy to harddisk!
AnyDVD comes with a UDF 2.5 file ripper, no need to install 3rd party
UDF 2.5 filesystem under Windows XP.
JimJ
  • Ut Prosim
I bet there's a group of execs somewhere that wish vinyl never fell out of the mainstream, simply to avoid the piracy issues :D
Irony is fun.
