0 Members and 1 Guest are viewing this topic. Read 8267 times.
Actually, I am quite impressed with what 5 watts will do. I could use just a tad more SPL, but not by much. Not much at all.One things for certain......Lin has given me a bug I won't be able to get rid of.Bob
You would really like my 15 watt/ch PSE, no problems with SPL.
Is that bug this or this ?
Umm......Dude, If you decide to sell this one it'll be a stretch. Not sure I want to know how much the other is.Bob
....Double the power (10watts) add 6Db for two drivers. Add another 5 watts brings about 3Db more, right??Yea, If I'm doing the math right, that should be enough.
Let's see, the Almarro is 5 watts....Double the power (10watts) add 6Db for two drivers. Add another 5 watts brings about 3Db more, right??Yea, If I'm doing the math right, that should be enough.
Mr. Vista, And just when I thought I had this watt/Db/gain thing figured out you go and throw an equation like that in the mix......You stumped me for sure. I thought for every doubling of the power you gain 3Db, and for every additional driver you add another 3Db??? Bob
you already have 2x5W and are thinking of going to 2x15W
With "normal" speakers of 88 dB/8 Ohm rating, there is a WORLD of difference between 5 wpc Almarro A250a MkII and 15 wpc A318B in authority, control, jump factor, liveliness way beyond the mere total capable dB's.
But I had already sold my A318A BEFORE I loaned Bob my A205A.
and being a 2 ch music only guy...........
