thanks again jens and rabbitz...
seems that everyone is concerned with the placement and isolation with the trannies- I understand that.
Any issues with the wiring of a selector switch? I will place the switch as close to the RCAs as possible and have some cotton sleeved silver wiring to try.
time to get that iron out!!! but first I want to make sure I've got a good idea of where everything will go...
jim
hi
hi
Ah,,what is more important, convenience, looks over sound quality or the reverse? Especially when you build it yourself.
I will always choose whatever it takes ( within reason and cost) for every approach to enhance the sound quality
Sound out of the speakers is made ( modulated) out of wall socket current. That is my first basic assumption.
When that "raw material" reaches my amp it must be as pure as
hell,ehh heaven.
So i start with a balanced transformer, (mothertransformer) into a series of filters( i use 2 relative cheap but good filters from
http://www.bluecircle.com/index.php?menu_id=1755last see how they clean up video signals ) and from there on ALL my current wires to amps or devices are shielded or twisted within themselves
The amps I made myself ( Aksa's and now building GK-1) have there power supplies outside the main box, in a stand alone box 30 cm away from the pcb of the amps. All the boxes are made of wood internally shielded for RFI
hum and hiss are still hearable very very softly with my ears 2-3 mm from the tweeter or speaker.
5 cm away from it, i can actually not hear it anymore. I give every box the tiniest led i can find red for the pws, blue for the preamp yellowgold for the amp and prefer to listen in the dark..
Before I had the balanced mother transformer i noticed thad at night my setup had this "magic" but very seldom during the day. With the balanced transformer i have this magic 24 hrs a day..
