The question was about convenience, right? You could of course take your pictures in the exact way you would with a film camera:- Plan how many pictures you think you might take and bring along enough film/memory cards (You could take small cards so no more than 36 shots fits )- Take your pictures as normal, always keeping in mind what opportunities you might have that day that you need room for- Don't look at any shots, don't organize or delete anything- Take your memory cards to a brick & mortar photoshop and order prints of everythingWhat would happen?My guess is that you will in a very short time start looking at pictures, deleting a few, feel a level of guilt over ordering prints of stuff you know is no good. etc.The things you miss, the things that chafe are your added convenience.....Just my take on things.Ferdi
There's a lot you can do in Photoshop to imitate the traditionally film-like look, but what interests me most about large format is that shallow depth of field and the whole movement\adjustment thing. I have recently attempted to fake this with "Lens Blur" but it's just not the same....
There is definite Photoshop work involved, with the overlaid textures on some shots etc., but I don't think the focus blurs per se are a part of post-processing. I have a feeling that's part of the basic view camera thing. I've seen that on lots of other shots. I could be wrong though, I've never used one. Here's some other examples:http://www.flickr.com/photos/brianray/376259178/http://www.flickr.com/photos/wesfrazer/273345463/http://www.flickr.com/photos/orbit1/11035456/Usually with shallow DOF shots (like flower macros) there's an even plane of blur around the subject, but it looks like with a tilt\shift camera you can get those dual blurs on either edge of the frame as seen in some of Tucker's images. I dunno, just guessing.
Hey! First as a photographer myself it is hard for me to say which is better. I'm currently using both. Depend on what I'm shooting and what I will do with it.
Actually, most of his photos are shot with a medium format camera. It would be impossible the capture those shots on 4x5 as focus is so tight through bellows extension. Thats why when you go to studios that use view cameras, they have you put a string to your nose to determine focus. It's a bitch to refocus then close the lens, then insert the film, then cock the shutter, then shoot.
But seriously, film is still VERY high in quality despite what the manufacturers want you to believe. The most important component in these shots is that he uses Color Negatives which holds a hell of a lot larger range-of-light than digital.
AFAIK there is only ONE lab left in America that processes Kodachrome.
Quote from: SET Man on 8 May 2007, 12:47 amHey! First as a photographer myself it is hard for me to say which is better. I'm currently using both. Depend on what I'm shooting and what I will do with it. Are you a professional photographer? What digital rig do you use?
I've heard that Diana Krall is penning a heartfelt ballad to the Foveon sensor for her next record, so the tradition continues even today.
