PC audio is it the next best thing?
0 Members and 1 Guest are viewing this topic. Read 10272 times.
audioengr
Re: PC audio is it the next best thing?
« Reply #60 on: 6 May 2007, 05:52 pm »
I tried wired and didn't hear a difference.
But I have tweaked the slim server settings to not transcode alac to mp3.
By default slim has the option to do that so you have to change that setting.
That is one possible explanation some people hear a difference?
Trying wired is not enough.  You must use a really good S/PDIF cable 1.5m long.  The cable adds jitter because of:
1) dispersion
2) losses
3) impedance mismatch
4) B/W limitations
5) too short or too long - see:
http://www.positive-feedback.com/Issue14/spdif.htm
steve N.
tomjtx
« Reply #61 on: 6 May 2007, 07:00 pm »
1) dispersion
2) losses
4) B/W limitations
steve N.
Steve,
I was speaking of my transporter so I don't need a S/PDIF cable. I use xlr analog out from transporter, using it's excellent internal DAC.
audioengr
« Reply #62 on: 6 May 2007, 08:30 pm »
1) dispersion
2) losses
4) B/W limitations
steve N.
Steve,
I understand now, wired network versus wireless network.  They should be identical except for the possibility of drop-outs due to other wireless networks and interference nearby.  I'm glad you are liking the Transporter.  Not my favorite DAC chip though.
Steve N.
