RA8 Layout???
RawB8figure
RA8 Layout???
« on: 27 Apr 2007, 04:28 am »
hey al,
     On the RA8 can you space the speakers so there is no gap on the bottom and also move the mtm up a few drivers, so from the top it would be wmtmwwwww, so the tweeter would line up with listen position. I don't mean to mess up your design, but I would like to have the front of the speakers even with speakers. What are your thoughts.
Rob
RAW
Re: RA8 Layout???
« Reply #1 on: 27 Apr 2007, 04:34 am »
Not a issue at all as long as the volume stays the same for the MTM and the outer woofers.
Plus the baffle stays at 8" width you will be fine.
