HVLP Spray System for $89.00
RAW
« on: 25 Apr 2007, 07:24 pm »
http://www.woodcraft.com/family.aspx?FamilyID=5853
Well people who have asked about finishing veneer or paint we have a possible solution.
We ordered this HVLP (High Volume Low Pressure) system which came from WoodCraft for $89.00 on sale.Just to see what can you get for $89.00 from a complete HVLP sytem for that little money.
A deal to say the least is the best way to say it.
This system comes complete all you will need less the finish you would like to use.If that is Lacquers or Shellac you will get great results with this small HVLP system.
Nothing fancy here you just mix you finish which ever you pick, with a thinner to the correct viscosity in the spray gun.Then attach the pressure hose from the pressure base and the other end of the 15' hose (yes 15' of hose) to the spray gun.
Plug in the spray system and you are ready to spray.
The results are stunning for a small system which you will use over and over for less than $100.00.
For those looking at how to apply finish to any speakers you may veneer or want to spray a painted finish.
Have a look at this HVLP system  aa
The info below is direct off Woodcrafts site.
Yes, that's the correct price. We were equally surprised when we had a chance to test this system. The results weren't just passable, they were actually very good.
Thin your finish to the proper viscosity (viscosity cup and thinning ratios included) and you'll get high quality coverage from stains, lacquers, water and oil-based finishes every time. HVLP stands for High Volume Low Pressure.
This compact unit has a 1000w motor that outputs air at 4 PSI through a bleeder-type spray gun.
The gun has a one quart capacity with a three position spray nozzle that allows you to choose the right spray pattern for any project; horizontal, vertical or round flat positions.
The 15' flexible hose is ideal for maneuvering around your project.
System includes; viscosity cup, wrench and instruction manual.
Berndt
Re: HVLP Spray System for $89.00
« Reply #1 on: 4 May 2007, 12:20 am »
love those cool new gadgets!
Daygloworange
  • www.customconcepts.ca
« Reply #2 on: 4 May 2007, 01:03 am »
Just some words of caution if you plan on spray painting. There are safety and health concerns that not everyone are aware of. In case you're not familiar with them, here's a link to some of the more important guidelines.
It takes a while to download the PDF, but it's worth having a looksee.  :thumb:
http://www.workcover.nsw.gov.au/NR/rdonlyres/BDA1CBEE-D62B-4DFF-9837-1C29DE64E75A/0/guide_spray_painting_415.pdf
Cheers
