Burson Audio Buffer
0 Members and 1 Guest are viewing this topic. Read 7133 times.
Double Ugly
Re: Burson Audio Buffer
« Reply #20 on: 9 Jul 2007, 11:22 pm »
Hi Brett,
I can't and won't address the question you addressed to someone else, but I can offer a 'FWIW' version of my experience.
In my system (source --> amps, see below), we noticed no tonal differences whatsoever (a good thing IMO).  What we *did* notice, however, was a much improved pace.  I don't understand why that would be, but both I and my wife were surprised and pleased with the effect, so much so that I would've purchased one right away if Wayne and John Chapman weren't working on a Buffer-based pre-amp.
We heard nothing "HiFi sounding. Bright and thin.", but instead got what we were already hearing presented in a better way.  Obviously each system is going to react differently, but most posts and reviews I've read indicate the results are usually positive.  I was impressed enough to purchase 3 pair of Burson's Discreet Op-amps for use in the Transporter.  I don't think they've arrived yet (shipped directly to Aberdeen), but I'm anxious to hear them in action.
Again, I offer this only to say that hearing 'startlingly improved' or 'significantly degraded' sound isn't necessarily the norm.  Obviously each system will react differently, and it seems my system and yours reacted similarly.
-Jim
SYSTEM
    *  Speakers:  SP Technology Timepiece 2.1s
    *  Amplifiers:  Butler Audio Monad monoblocks
    *  Source:  Aberdeen Components-modified Slim Devices Transporter
    *  Interconnects:  Stealth Audio Cables Indra
    *  Speaker Cables - Gregg Straley's Reality
    *  Tweaks:  Star Sound Technologies Audio Points or Sistrum stands beneath every component, stands filled with Star Sound’s Micro-Bearing Conductive Steel Fill Material
bprice2
« Reply #21 on: 10 Jul 2007, 01:22 am »
Rich,
 :scratch: Now you've got me thinking what I heard through the tuner could be due to something else...damn variables.  :duh:
Thanks again.  :thumb:
Jim,
Please feel free to express whatever opinion you have in regards to my questions...they're for everyone. :)
Jim, I'm sorry I don't know what "pace" is.  Would you (or anyone else  :wink:) mind explaining?
That is good to hear.
I am coming to the conclusion that more must be done in regards to treatment in my listening room.  I think I have a few more problems than I had already realized.  Continuing to critically analyze components in my system before doing more with my room is not going to be beneficial, I think.
Double Ugly
« Reply #22 on: 10 Jul 2007, 04:21 am »
What I mean is the presentation was livelier, 'sped up' if you will.  I didn't notice a deficiency before the Burson was inserted, but removing it coincided with a perceived slowing of the music (i.e., a decrease in pace).
Strange, I know, but that's what we heard.   :scratch:
-Jim
bprice2
« Reply #23 on: 10 Jul 2007, 03:52 pm »
-Jim
Interesting....  For me, critical listening is like going through a check list..."pace" is not on the list.  I'll have to add it.
Thanks, Jim.
Brett
zybar
« Reply #24 on: 10 Jul 2007, 04:15 pm »
-Jim
Thanks, Jim.
Brett
No need to add it to the list...
Just check to see if your toes and hands are tapping more than usual to the sound of the music.
George
richidoo
« Reply #25 on: 10 Jul 2007, 04:22 pm »
Brett, if your Sansui is stock and has had no maintenance that you know of, it very well could need a good cleaning and alignment. They are coming up on 30 years old and electrolytic caps in the power supply and elsewhere are really only reliable for 15 years, less for crappy brands. The variable capacitor used as a tuner has adjacent plates with air dielectric. If the plates get dusty the capacitance gets screwy, so they get cleaned too. Your volume pot on the tuner should be cleaned too. Analog FM tuners also require a periodic alignment. I have no idea what an alignment is, but it allows the tuner to lock in on stations much better. You can probably find a local tech who can clean it, or you can do that yourself with Caig products (ask someone you trust online how to do it.) Techs with equipment to do FM alignment are getting more rare nowadays. If you go to fmtunerinfo.com there is a list of other very qualified techs around the country. Alex Lok in Raleigh (theanalogstore.com) is another good tuner guy, has all the equipment, he is a friend of mine, but I used Ken because he is a Sansui expert, rebuilding 5-10 of them per month! I think Ken's work set me back about $400, quite worth it to me.
The stock output RCA connectors on the Sansui are nickel or something not so great. After 30 years the crud could be quite serious. Cleaning them and the inside of the IC connectors that have been connected to them might give you a noticeable improvement. You can use Caig or just q tip (or paper towel if it needs some scrubbing) with rubbing alcohol.
I was thinking last night  :o  that the Bolder ICs are likely to be very low capacitance because Wayne's SB mod removes the output gain stage so output current is a known issue. He would not recommend a IC cable that would make the situation worse. I also forgot to say that resistance is usually not an issue with any quality copper conductor IC wire unless the wire ga is too small for the load, or the length is very long, or some combination of both. Any 1 meter cables designed by reputable company will have neglible resistance. Lamp cord uses diluted, recycled copper which is anything but pure. Decent ICs and speaker cable are a great investment, doesn't have to be expensive, just not "AV cables" from Target. Of course expensive cables are often more refined (but not always- buyer beware)
Sometimes you will hear the phrase "PRAT" meaning Pace, Rhythm, and Tempo. It is the feeling of rhythmical drive that you get when listening to music with a beat. Jim's description is characteristically more sophisticated and excellent. ;) You will know it when you hear it, it is more of a feeling than a sound, your body wants to move with the music. It is a subtlety that will become more obvious as your listening experience and system performance increase. A good preamp and a good source (strong output stage :) ) are key to this, as well as solid, clean  60-200Hz bass response from speakers and room acoustics. A carpet on the floor will help reduce floor reflections a little which can smear or null the bass at those frequencies and cause them to sound weaker, losing prat.
Seeya!
Rich
