0 Members and 1 Guest are viewing this topic. Read 6275 times.
Posted by: RudolfI am following a german forum discussion about the B1 http://www.hifi-forum.de/viewthread-159-2034.html. According to that the B1 doesn´t work according to specs and has quality problems (resistors with wrong values put in). I would hesitate to buy their products without the opportunity to test them with scrutiny in advance.
How about this from marchandhttp://www.marchandelec.com/xm46.htmlLow level passive your choice:2-way in a case1-way in a little boxjust the boardsOnly problem is it's not adjustable, you need to know the frequency you want.Perfect if you just need a high pass to pull the bass out of your mains, then use the adjustable low pass on your subs amps.
Scott, is that Pyramid a mono item?
I never thought I would ever see anything that made Behringer look up-market!
For pure high pass, I would likely spend my dough here, on these, but I am not sure of the insertion loss on them?http://www.audioc.com/accessories1/misc/hipass.htm An 85Hz 6db/octave would likely make the Maggie happy, and the price is certainly good.
We discussed those in this thread.http://www.audiocircle.com/index.php?topic=38267.msg343354;topicseen#msg343354The ACI look to be the same.
I've been thinking about getting the B1 to control an amp for stereo subs; and trying to read through the linked thread through an online translator. I can't seem to download the schemo that is linked on the first page of the thread (of the F1). Did you happen to download it and is there any way you could post it here?
