0 Members and 1 Guest are viewing this topic. Read 26811 times.
Spoken like a guy in need of a clue.
Topic: Synergy, is it measureable?No. And neither is the smell of a fart. Not everything is measureable. End of discussion.
Resounding disconnect from reality there regarding pre/post echo.
I don't know about others, but my NOSE can measure it.As far as I know there are no man made instruments than can even measure it let alone with the accuracy of my nose.I also have NO idea what others are smelling, is it the same or different from what I smell? Could it be the SAME with ears and music? Lin
QuoteNo. And neither is the smell of a fart. Not everything is measureable. End of discussion. Actually, I believe that that is in fact measureable. But, I do get what your intended meaning is. Cheers
Quote from: Daygloworange on 10 Apr 2007, 04:18 pmQuoteNo. And neither is the smell of a fart. Not everything is measureable. End of discussion. Actually, I believe that that is in fact measureable. But, I do get what your intended meaning is. CheersI think any audio discussion like this comes down to certain things that we have to agree are not measureable. You can't measure how some things make you FEEL I guess is the point.
Quote from: JohnR on 10 Apr 2007, 02:37 pmYah, I'm with Dan. I have my synergo-meter right here in fact, and it's off the scale! Thank God for Engineering Education and the Righteous Way.I've got one too John. Looks kind of like thisI also have my scent taste and beauty meters somewhere around here...
QuoteResounding disconnect from reality there regarding pre/post echo.Can anybody elaborate on that? I was equating that to print through on analog tape.Cheers
In neither case is the audibility of the effect connected in any way to the quality of the playback device.
If every phenomena in audio can be measured with contemporary equipment why can't speakers, amps, etc. just be designed on the computer with spreadsheets and forgo a/b testing with ears? Raj
Quote from: eric the red on 10 Apr 2007, 02:48 pmQuote from: JohnR on 10 Apr 2007, 02:37 pmYah, I'm with Dan. I have my synergo-meter right here in fact, and it's off the scale! Thank God for Engineering Education and the Righteous Way.I've got one too John. Looks kind of like thisI also have my scent taste and beauty meters somewhere around here... No more worries now Kevin; Everyone can connect up to the meter shown above to measure audiophile synergy. Case closed. d.b.
You were correct in that equation. The fault is in the medium - vinyl or tape. In tape it can be caused by incorrect storage (tails in instead of out) or by a too-thin tape stock.With vinyl it is a mastering decision involving, primarily, groove spacing choices as relates to signal level. If the groove spacing or pitch is inadequate, the "wiggles" in that groove affect the shape of the adjacent groove to an audible extent.In neither case is the audibility of the effect connected in any way to the quality of the playback device.
Quote from: Dan Banquer on 10 Apr 2007, 04:27 pmQuote from: eric the red on 10 Apr 2007, 02:48 pmQuote from: JohnR on 10 Apr 2007, 02:37 pmYah, I'm with Dan. I have my synergo-meter right here in fact, and it's off the scale! Thank God for Engineering Education and the Righteous Way.I've got one too John. Looks kind of like thisI also have my scent taste and beauty meters somewhere around here... No more worries now Kevin; Everyone can connect up to the meter shown above to measure audiophile synergy. Case closed. d.b.It's right here rajacat, just change the meter label and it will give you certified eric the red approved masurements for any piece of audio equipment. d.b.P.S. I hear John R. likes it too.
