0 Members and 1 Guest are viewing this topic. Read 23361 times.
Hi Crooner, Here are some pics of Tanchiro58 and my DIY power supply. With all the upgrades, this power supply is rock solid. This pic was taken before I added the bypass cap across the big Elna Cerafine 10,000uF/63v and replaced the two diodes with Hex Fred.
I have a 1u chassis that I'd like to transplant the SB into so that I can have room to try such things.
I think I saw a pic of that chassis before .... I'm also in the hunt for a bigger chassis to house the SB3 too but still haven't found one that I like yet.
At this point, I don't know if it is worthwhile, but if there is min orders or other impedances to ordering the tx's, do any of you guys want to get together for a mini-groupbuy on these transformers. I am willing to pick one up to test out.
Josh,count me in - postage should not be a problem.Brad
Hi Crooner + F-100nice power supply builds.I also have one of those 3 amp Power One modules, although I managed to melt the transformer when I mis read-the connection info and left one of the wrong links in place. I will still use the Power One pcb and now intend to add a different EI core transformer - the thing is I dont know the AC output voltages on the pins marked A-AT-A - I could guess at around 4-0-4, but as you both have working units, would you mind measuring those voltages please?Brad
Hi Tan,thank-you.do you mean 9v AC between A-A, with AT measuring 4.5v from either A pin?I am not worried about the lead free option as I still have plenty of leaded solderthe Power One PS cost £30 so its worth me replacing the transformer, which I can do for less than £10, unless you know of a source of lower cost Power one modules? should I talk to F100 about this?Brad
