0 Members and 1 Guest are viewing this topic. Read 4372 times.
hey rick,just hooked up one (finished with no finish) ssr.wow!!!!crystal clear, superb!construction on the other box is progressing, i'll keep you posted.thanks rick,michael stevener
What version you guys are using, sealed or ported? I' m going the ported route, and then plug the port for use as a satellite/sub. I don't think the larger box is gonna hurt the mids. Anxiously waiting for my own kit.
Rick,A question, if you don't mind...Would the crossover need to change when going to a sealed design in a smaller cabinet? (The baffle size is 10 X 17 for the PE .75 cu. ft. cabinet if I recall correctly.) Or would a special cabinet with a 9" baffle be required? (The other .75 cu. ft. cabinet from PE has an 8" baffle, I think )WEEZ
Rick, you lost me Your SSR uses a 1.0 cu. ft. cabinet with a 9" w baffle. The (2) choices for a.75 cu. ft. cabinet from PE are either 10" or 8" wide. So are you saying it's best to stay with a 9" baffle? Even if sealed?WEEZ
