Can you recommend some good audio rack please?
0 Members and 1 Guest are viewing this topic. Read 6461 times.
arthurs
Re: Can you recommend some good audio rack please?
« Reply #20 on: 3 Apr 2007, 07:16 pm »
There's just a small rubber pad between the shelf and the rack....the VTI is a great price/value rack....you can better damp the shelf to the rack (per your question) and you can also fill the legs with sand or shot....each of those makes them a bit more solid...
« Last Edit: 3 Apr 2007, 07:31 pm by arthurs »
