3. Not as great with more complex music
I don't follow, because I get wonderful results on big orchestral, rock, etc. What was your associated equipment, especially speakers, and which model did you own?
4. The pair I had were old and reliable for the six or eight months I had them
That's not very long. Why did you sell them?
Speaker impedance is a consideration at least on the S-30 and M-60, somewhat less so on the MA-1. ZERO autoformers have been used successfully in some instances, for example one customer had good results with M-60s driving Martin Logan Summits.
Yes, the amps throw off some heat, but not dramatically more than solid state amps producing a significant amount of power in Class A. On the other hand MA-1s or MA-2s can be a bit much in small enclosed rooms in warm weather. My room is on the smaller side but is partly open to a couple of other rooms, and even driving the Sound Labs the MA-1s raise the room temperature perhaps 3 to 5 degrees.
The newer models with their self biasing are simple to use. No tube swapping needed, and average output tube life is estimated at 10,000 hours. If you accidentally short the speaker terminals with them on nothing happens, and the music resumes as soon as you correct it.
Disclaimer - I am an Atma-Sphere dealer.
