0 Members and 1 Guest are viewing this topic. Read 7436 times.
Yup - that's basically the idea. That way, you can keep the speaker relatively close to the front wall for some augmentation if you want and also bring the seat to 38% (closer than halfway of the length - nearer the speakers). This would provide a more nearfield setup which many times IMO is better in a smaller room.Bryan
I keep reading about mixing absorption in with diffusion....my room is a bit larger than Kent's (11x16 with high ceilings), but I'm trying to figure out if diffusion is as important in a smaller room as it is in a larger one? If so, what are the prime locations for diffusion panels?
Don't overestimate the small increase in bass level from having loudspeakers near walls. If your current speakers play to a low enough frequency you don't need a sub. And if they don't go low enough you'll need a sub whether the mains are near walls or not. That is, being near walls only increases the overall bass output level a bit. It doesn't extend the speaker's inherent response to a lower frequency.
Do either the side wall OR back wall provide augmentation?
Begging Ethan's pardon, here is your $500 solution. http://www.pcrush.com/prodspec.asp?ln=1&itemno=83041&refid=1058 I would put some DIY absobers on the back wall and cover it with the tapestry.
Alwayswantsmore,How did you draw your picture of the room?
