Driver Qt + baffle size? = Qts?
0 Members and 1 Guest are viewing this topic. Read 9336 times.
johnk...
    • Music and Design
Re: Driver Qt + baffle size? = Qts?
« Reply #20 on: 4 Apr 2007, 07:09 pm »
ABC address the woofer system and midrange of a 3-way dipole system like the NaO II or NaO Mini. It does not address the mid tweeter crossover. Discussion of suitable tweeters is directed at domes and appropriate crossover points. It was not intended to model rear tweeters.
The mid/tweeter x-o is left to the user to do with pother software. The point of ABC is to reduce the 3-way dipole problem to a simple, conventions 2-way crossover problem.
I looked at tweeters similar to the A-C ribbon when developing the NaO. It worked ok, but I didn't like the result. But I'm not particularly a fan of ribbons.
rick57
« Reply #21 on: 5 Apr 2007, 02:25 pm »
Fair enough. Perhaps you could have an FAQ addressing these questions on the web page . .
Cheers
