0 Members and 1 Guest are viewing this topic. Read 37649 times.
subjective tests are not good to show up distortion(inaudible),you can do thd measurements,however whatPneumonic said was inaudible distortion,there is no sonic difference in that case.
What sonic difference exists between a low powered amp that "performs" with inaudible levels of distortion and a high powered amp that does the same?
I can say it's very difficult to tell the difference between my 5 wpc SET and my 375 wpc Crown XLS class D amp until the volume gets loud. But it's really dependent on the speakers, my SET won't do a good job with speakers that use drivers with heavy cones because it doesn't have the damping factor but on my speakers the cones are 2g and they sound pretty much identical.
I wish I was that handy. I can use a soldering iron but I am not very adept when it comes to following schematics for electronic gear from scratch.Besides, where do you get the kit or plans?
Output boards:http://www.diyaudio.com/store/amplifier-circuit-boards/power-amplifiers/first-watt-clones.htmlPower Supply boards:http://www.diyaudio.com/store/amplifier-circuit-boards/power-supplies-accessories/universal-amplifier-power-supply-v3.htmlPre-drilled Chassis:http://www.diyaudio.com/store/amplifier-chassis/full-width-40mm-heatsinks/deluxe-amplifier-chassis-enclosure-4u-216.html
Cool, what about all the electronics, power transformer, schematics, ect.?You have peaked my interest.
The answer to the original question on how much power you really need is -- ALOT. Here's why: generally speaking, you can recognize the deficiencies from an underpowered system, but have you ever heard an audiophile complain that his massive amp sounds too powerful? After trading out a bunch of amps over the years, I came to the conclusion that 250 wpc into 8 ohms is the minimum I would consider. My amp snickers like a tickled two-year old at the light load I'm asking it to carry. I'm not suggesting that lower powered amps generally sound inferior by any means, but I'm saying that to be on the safe side, I want more available power than I'll likely ever need.
Even with a 250 watt amp, I bet it's mostly running 1-2 watts continuous, maybe even less, and only going over that on big crescendo's and bass thumps. Of course if you're playing house music then those bass thumps are rather continuous.
The point I was trying to make is that this thread is off....power and spl is in log terms, not linear. Thus 2,4, 8, 15, 32, 64 is linear not normal terms. What one needs for transiet power, i.e. <1% of the time and what one needs from an amp isn't max power. Tube amps tend to compress, SS amps tend to clip (nasty sound).
Electronics - Mouser or Digi-Key, sometimes you can find someone selling kits (I was lucky last time).Transistors must be matched, there's a couple guys who sell those.Antek are probably the best value in transformers, or Avel Lindberg.Schematics are available, but not really needed to stuff the boards.Look for the build guides, the author is very helpful. (and local to me).The Amp Camp amp is a very simple build and sounds great. Only 5 watts, but it might drive your bedroom system fine. I'm currently working on an Aleph J.Have fun with it.
Although it isn't discussed much, with speakers with lots of drivers, back EMF can be a factor in controlling the speaker. Although my GR-Research LS9's are rather efficient, they need a couple of hundred watts/channel to maximize what the do well, dynamics.
Big power basically translate into higher output rating in watts for A/B or more unswtiched dynamic power in Class A. What powers the output devices are capacitors. What keeps the capacitors stiff is the transformer VA size. The reason why you want a big VA size transformer is because the amp sees the local neighbourhood transformer through the house plug, wiring, fuse Box, and hopefully not any other Junction boxes. This all translates into high house impedance. Which screws with your dynamics. Big transformers keep a reservoir of power to keep those output capacitors stiff. Which allows for transient power to your speakers. Big power is a bandaid fix for a 15 amp circuit. Aside from the obvious huge speakers that will only work with big amps. Good work around is to plug your amp into a suitable transformer conditioner.
Werd, there's ten things going on for every one you've said.Bigger amps with larger reservoirs and higher headroom suffer less from the power problems that represent power that does not exist. Essentially the amp acts sort of like a PFC in a manner by being above and beyond the duty of needing anything near. However all the impedance etc aren't a loss of power so much as they're interfering, and usually with noise.Large VA transformers are good for in-rush current, and very useful for when it'll cost you an exorbitant amount of space and money to populate with enough capacitance to make up for needing the efficiency of a very large transformer. It can be done easily with small devices, very large capacitor reservoirs for their size to the point where you turn it off and the device plays full volume for a few seconds. You can't do that with a Pass amp. You probably can't afford too... The size retains thermal efficiency, particularly at 60hz, and not necessarily a relation to the amperes needed. This is all about power delivery, not the amount. 15a is more than enough to service any Pass amp WITH EASE. But we're talking about an amplifier that has a constant current power supply so it's always using power, and sometimes more. under load the capacitors actually get a work out, so the efficiency of in-rush current means a lot. The inrush current isn't necessarily high, but it's happening a lot. It'd be wise to beef the capacitance but we're talking soft starts and CH-CHING! At least for some better capacitors. Believe it or not, I'm on the job of a PSU board for the F's... Not the turbo though, totally unruly in size. Perhaps I'll quarter up the pieces but it destroys the benefits quiet a bit.
