More power is better than less power.
It was instructive to go through the exercise, but I am not looking at 900 watt amplifiers; our house is already heated.
You know the saying "less is more"...
Not when it comes to dynamic potential in sound reproduction.
I guess these new-fangled cheap high power class D amps are difficult to compete with, eh, George? Are you still making and selling amplifiers?
As Big Daddy Don Garlits used to say, "There's no substitute for displacement." Goes for stereos as well as A/A fuel dragsters.Doc
While I definitely understand the idea of getting a massive amp and being set regardless of speakers one pairs with it, I have yet to hear a massive amp with multiple gain stages (that didn't cost an arm and a leg) sound as pure, detailed, and clean as a lower watt amp with only one or two gain stages when set up on appropriately sensitive/efficient speakers.........or speakers of average sensitivity used in a somewhat nearfield setting. It's horses for courses. You wouldn't drive a top fuel dragster on a winding track. At the same time, you wouldn't drag race a F1 car. It's not that you couldn't, but there are better tools for their respective jobs.Don't get me wrong. I like all this stuff : High power, low power, high efficiency, low efficiency.......As long as it sounds good / engaging / makes me want to listen / has no obvious unnatural sonic shortcomings, then it's all good.
I had a friend with the setup you described -- high efficiency speakers with a lower watt tube amp. He swore it sounded good. Then I brought my massive amp to his house, hooked it up, and his music immediately came to life. Afterwards, he still swore his flea amp sounded good. Some people prefer low powered music -- hey, whatever floats their boat.
You can have a First Watt amp if you build it. That's what I did - I built an F5 for my tweeters and a First Watt Burning Amp 3 (basically an F4 with gain) for the mids. And I use a Crown K2 amp with 800 watts on the bass. If people really want their speakers to "come alive" they should consider kicking that power sucking passive crossover to the curb and going fully active.
If you can hear and verify with your ears distortion in my 500wpc system at moderate to moderately loud volumes coming from my amp then I will give you $100. Maybe with cheap or a poorly designed amp and preamp you can hear it.
