0 Members and 1 Guest are viewing this topic. Read 37702 times.
I don't think so, Wayner. Look at headphones. They barely need any power. Know why? They're right next to your ears, not because they're efficient or inefficient. So you're partially right. Room size is important to consider, BUT how much power one needs to reach certain SPLs (at the listening position) depends on how close or far the listening position is. It isn't like the sound from our speakers shoots straight into our ears (from more than a foot or two away), the way it does with headphones. One could have a HUGE listening room, but if they only sit 2-3 meters away, they may not need tons of power. You only need tons of power if you're trying to energize the entire space. Also, power requirements DO depend very much on how dynamic the listening material is. Even if a person sits 2-3 meters from their efficient speakers, if their amp doesn't have enough headroom, and they love listening to classical at high levels, transients will surely be blunted. There's no opinning around this stuff.
It's not important how close or how far away your are, unless you are in a very large music venue. An Amp with about 150WRMS will suffice in almost every event. This discussion has nothing to do with headphones, so lets keep that for another topic.The best thing you can do to improve a system is to introduce a sub-woofer. It can enhance the listening environment without over powering it with huge dynamics, especially in a smaller listening environment (which most of us listen in).
You need enough power (amongst other things) to drive the speakers that are housed in your room, to the desired volume you enjoy while playing the music you wish, without clipping. Since the variables above are so many, it's impossible for anyone to tell you what is the correct answer in your particular and specific case. What's really needed is for you to measure your amp's output to see if you ever clip it under the above conditions. Not practical for most people to do unfortunately. If it were, I suspect more people would realize that they run underpowered amps.
The problem with high efficiency speakers isat they tend to deviate from a flat frequency response. There are very valid reasons that many of the speakers that are considered to be in the upper class of audio reproduction are of lower to mid efficiency levels (84 to 87 db/w). A lot of the high efficiency speakers lack lower bass, and can be a bit ragged. I'm not saying they all are like that. What I am saying is that it's hard to find ones that are neutral across the entire frequency spectrum.
+1 And a lot of people may also find that they don't need / use nearly as much power as they believe. It's a balancing act that is going to be different for everyone's individual needs / habits / preferences.
This is from a post on similar thread in the AVS forums:
No, it's not that at all. It's all about speaker efficiency. Then it's about the room size and what listening levels you listen to. Almost every one of your statements is wrong, IMO.......
You do realize you necroed and quoted a 7 year old thread? . Nothing wrong it but it was pretty good.
Yes, speaker efficiency is where it starts as I did above, from there it is by desired dynamic range, background ambient, and listening position.Start with speaker efficiency, say 90 dB. This means 90 dB of sound pressure power from 1 watt of input power measured at 1 meter. I think most reading this know this, but from here you can get everything.Next you need know how quiet the room is, typically 50 dB, but 40 dB is achievable (this from Xiph.org). Around 25-30 dB you will start to hear the hum from a nearby lightbulb. If you don't hear your lightbulbs, your room is above 30 dB ambient (0 dB in this case is the limit of human hearing).To hear a sound in a 50dB ambient room, you need 53 dB of sound energy from the speaker (3 dB above ambient to 'register' on you ears)A 1 meter, this requires -37 dB down from 1 watt (53-90 = -37); this is 200 uW. If you want 60 dB of range (classical music, without clipping) you will need 20 dB of additional gain above 1 watt (50+60 - 90), so 1 watt becomes 100W (at one meter). Move 2 meters away, double the distance, and increase by 4X, or 400 watts. Sit three meters away in a larger room, and you will need 900 watts of amplifier power.If you had a very quiet room, say 40 dB ambient, then the 400 watts requirement becomes 40 watts, and the loud transients won't actually be painfully loud, just really loud. A 96 dB efficient speaker in a 40 dB room will need just 10 watts at 2 meters to be as (relatively) loud as 900 watts driving a 90 dB speaker in a larger, slightly noisier room.So it really varies. Start with speaker efficiency and ambient room noise, everything else follows and is straightforward. But most people don't need that much dynamic range. From a survey of popular music, even the widest range acclaimed albums had less than 20 dB of range (16 dB from Dire Straits, Bother in Arms, for example)
