0 Members and 1 Guest are viewing this topic. Read 37643 times.
What's to stop you going back to the store where they recommended the MF KW 750, borrowing it for a day and finding out for sure if that's the answer? If you like the result you could then start looking for that much power in a solid state amp but cheaper.At least you will know.Then if you decide you still can't live without tube sound you know you will probably have to look for some significantly more efficient speakers. 94 dB/W will give you the equivalent of about 500 WPC from your 100 watt tube amp.
