cases
0 Members and 1 Guest are viewing this topic. Read 873 times.
guest1632
  • Guest
cases
« on: 16 Mar 2007, 08:07 pm »
Hi all,
Firstly, let me apologize right off, because I wasn't certain where to put this topic/question.
I am about to build a new amp, and I need an aluminum case 12 inches deep and wide with the insides to be about a hair over 3 inches, with no more than the standard 3.5 inside dimension. The front of it needs to be open to accomodate the heatsink. Mike with DIYenclosures just has certain ones he sells. I don't have the tools to do to much metal work. So anyone ehlp would be apreciated.
Ray
JoshK
Re: cases
« Reply #1 on: 16 Mar 2007, 08:38 pm »
par-metals' 20 series is close to that size.  either 20-12124x or 2012123x depending on which is more preferrable.  This is 3" or 4" high, but I am guessing this is outer dimensions.....otherwise you can choose to have one custom made.
guest1632
  • Guest
Re: cases
« Reply #2 on: 16 Mar 2007, 08:43 pm »
got a link for me. Thanks.
Ray
JoshK
Re: cases
« Reply #3 on: 16 Mar 2007, 08:44 pm »
guest1632
  • Guest
Re: cases
« Reply #4 on: 16 Mar 2007, 10:03 pm »
http://www.par-metal.com/
Thanks Josh. Appreciate that. I tried just www.parmetal.com and got a site about ductwork. lol. Gotta have the dash! Thanks again.
Ray
