How many people would be interested in an OB Design?
0 Members and 1 Guest are viewing this topic. Read 5753 times.
JohninCR
Re: How many people would be interested in an OB Design?
« Reply #20 on: 13 Mar 2007, 11:01 pm »
Russell,
I'm talking about the lower octave for music, not HT.  All it takes is Linkwitz's DipoleSPLmax spreadsheet.  Plug your driver(s) Sd and Xmax in.  Then it's easy to determine what the limits are and adjust your design from there.  The key is how you delay the rear wave within your footprint limitations.  While placement and room can help in the bass department, an open design starts with an SPL goal at a given low frequency threshold.
I definitely agree with your friend.  Sure we fall in love with the big soundstage and open sound of OB mids, but it's the OB bass that keeps you there for the long haul.
Russell Dawkins
« Reply #21 on: 14 Mar 2007, 12:14 am »
If you go to their site and click on Press/Reviews and look at the reviews you will see that
1. they are taken seriously by those who take sound seriously (because their livelihood depends on it!)
2. they are approaching this from a valid, authentic engineering perspective.
I think it makes very good sense to operate under the resonant frequency is you have the woofer area and amplifier power to permit that luxury. The alternative, operating intentionally through the resonant frequency of a driver is a necessary expedient, nothing more. The designer usually avoids the resonant frequency of the mid (in a 3 way) and the tweeter for good reason. It's just that ordinarily it's not so easy with a LF driver, so we try to work around it. I know which of the two scenarios I would expect to sound better, though!
Kevin Haskins
« Reply #22 on: 14 Mar 2007, 04:41 am »
Russell,
I'll model some drivers in a box and show you what I mean tomorrow.   Its fairly simple to show how much cone excursion is needed from a 18" driver to get output below 10Hz.   Its also simple to show the power needed in that size box.  Since they don't get special exclusions in following the laws of physics I'm fairly certain I can convince you that their specifications are inflated no matter what reviewers think of them.   :)
Russell Dawkins
« Reply #23 on: 14 Mar 2007, 04:54 am »
Kevin,
while you're at it, maybe you should model 2 long throw 18s because that seems to be what their woofers evolved into.
Russell
Kevin Haskins
« Reply #24 on: 14 Mar 2007, 05:01 am »
Kevin,
Russell
Sure... that will certainly help them on the acoustic side.   It won't help much with the power needed since now the drivers have to work within half the original volume.   The models show a lot of the dynamics at work.   You know that old saying... a picture is worth a thousand words.   For an engineer an good graph is worth 10,000 words!
Kevin Haskins
« Reply #25 on: 15 Mar 2007, 01:06 am »
Ok... busy day but I'll get this answered before heading home.
I went to their web site and did a little research.   They leave themselves an "out" by mentioning the following in their documentation.
HOW LOUD AT 8 HERTZ:
While the INFRASUB-18 will reproduce 8 Hz, it is not audible nor does it have enough acoustical power for you to feel it. The measurements are taken at close range with sensitive instruments. To achieve a flat response, full amplifier power is used at the lowest frequencies and very little (<1 watt) in the upper frequency range. The INFRA dual integrator provides the correct signal strength and therefore amplifier power at each frequency. As the frequency is lowered the power and excursion required to maintain a flat acoustical response at high SPL become enormous and not practically attainable for a single driver system. Fortunately the improved phase response, one of the main benefits of an extended subsonic acoustical response, is preserved because the music content is typically not demanding high power subsonic reproduction.
The ideal listening scenario is to have a full bandwidth 8 Hz playback system and play a good recording without low frequency noise present on it. The playback system can then benefit from the improved phase response without requiring excessive power in the lowest octave or engaging the Dynamic Filter circuit.
Not audible is certainly the truth.   Their BS about phase is just that... BS.  Here is a Eminence Defimax 4018 (18" driver) that will do as well as any other 18" driver for comparison.   The 4018 isn't what I'd choose for a sealed box application but it will work fine to illustrate how much driver excursion is needed.
First off LSPCad wouldn't even let me dial in the amount of gain I'd need to get this to work in a three cubic foot enclosure.   I'm sure I could get around it if I monkeyed with it but I don't see the point.   I moved the box volume up to 67 cubic feet!  Yes... just over twenty times the volume of the Bag End.   That gives the Bag End a little advantage.   :wink:
Here we are with 500W @ just 26db extra gain at DC.   I'd never dial a Linkwitz transform in with this much gain at DC but to get down this low with a single 18" I had to do the unreasonable.   At 8Hz that is equal to about 23db of gain, or about 3800W.    You would basically be able to remove the voice coil with a syringe because it WOULD melt if you managed to find an arc welder that could put that much power into it.
Looks pretty good... 115db @ 16Hz.   Of course its down to about 101db by 8Hz.   This is a 2PI model measured from 1.0M.    Looks fairly reasonable if you can live with a 67 cubic foot enclosure.  :lol:
Here is a shot at the cone excursion to get these levels.
Hmm... little problem.   Our cone needs to have about 75mm of X-max one way.   If we went with a more reasonable spl level we could get the excursion levels down.   I could probably use a Tumult motor on a 18" basket and get 90db @ 8Hz 1M in 2PI space given a large enough box & a huge amp.   Of course you would be right at the mechanical limits of the driver and you would be able to get about 80db at the listening position.   I'd never design a subwoofer that way.   You have no control over what program material is going to play at so you would end up with a smoked driver in no time.   If you set a limiter on the system you could dial it in so that you wouldn't clip the amplifier but that wouldn't stop you from going past the mechanical limits.   I'm sure they use a sophisticated limiter otherwise they would have a terrible reputation.
This is the reason I laughed at their specs.   They are just marketing nonsense.   They have nothing to do with a reasonable design and its pretty questionable to cook your specs and report them in a way that doesn't match the industry standards.
« Last Edit: 15 Mar 2007, 01:28 am by Kevin Haskins »
