DVD Copying software?
0 Members and 1 Guest are viewing this topic. Read 1069 times.
chgolatin2
« on: 8 Mar 2007, 04:50 pm »
I have the DVD Fab software "trial" version.  Any good recommendations for a good quality DVD burner.  Some DVD's have anti copy software and at time DVD Fab gives me a hard time.
Any good recommendations and links?  Thanks!
Imperial
  • Love keeps us in the air, when we ought to fall.
Re: DVD Copying software?
« Reply #1 on: 8 Mar 2007, 05:09 pm »
http://www.alcohol-soft.com/ But, and this must be stressed, not all makers of dvd burners will have full support in any software program
http://support.alcohol-soft.com/en/drives.php
So going to the forum or homepage of your current choice and see if the drive will work as adverticed with the program.
http://www.lgsoftwareinnovations.com/index.asp with a LG burner... well that will work!  :roll:
http://www.dvdtox.com/dvd_ripper.htm ...
As for dvd-burner hm... Check this site: http://www.burnworld.com/
Imperial
« Last Edit: 8 Mar 2007, 05:24 pm by Imperial »
mca
« Reply #2 on: 8 Mar 2007, 05:24 pm »
I have been using this with no problems:
http://www.slysoft.com/en/
Imperial
« Reply #3 on: 8 Mar 2007, 05:48 pm »
Then there is the fact that not all brands of DVD-RW discs will work best either.
This is a science... of it's own!
Program + recorder/reader + dvd-media(RW) disc = good copy!
You need a combination of all 3 to get that perfect copy.
Sho nuff!
Then what it all comes down to is this:
- If you have a disc you wanna backup.
You most likely have to go on a quest to hunt for the method if it proves difficult to do!
A quick hunt on the web turned up the name:
Lite-On LH-20A1P as one of the best all round writers just now!!
BenQ DW1640 is also real good at the "ripping game".
Imperial
« Last Edit: 8 Mar 2007, 10:35 pm by Imperial »
gooberdude
« Reply #4 on: 9 Mar 2007, 02:51 pm »
AnyDVD works 100% of the time for me.    www.slysoft.com
patrickperry
« Reply #5 on: 9 Mar 2007, 03:23 pm »
I use this combo and there isn't a disc I can't back-up yet:
Software : dvd shrink (free ware) with slysoft anydvd running in background for ripping
                Nero burning rom or recode for burning to disc
Burner     : benq 1640
                plextor px-716a
dvd shrink is very flexible and easy to use.  Benq 1640 has been discontinued and extremely hard to find one new.  Used one will pop up on ebay once in a while.  You can pick up the px-716a on ebay for ~$80.
Make sure to use good media like verbatim and stay away from memorex.
Happy burning!!!
patrickperry
« Reply #6 on: 9 Mar 2007, 03:41 pm »
There are several refurb benq dw-1620 on ebay right now for $30 shipped.  I just picked one up.  This is also an excellent burner, some even prefer this over the 1640.  I'd choose the 1620 over any sony, samsung, hp, or memorex burners.
chgolatin2
« Reply #7 on: 10 Mar 2007, 05:46 pm »
With BenQ products I dont need copying software correct?   :scratch:  Seems like a good solution for me, so far I like the 1670 and the 1655 lightscribe option... Hmmm nice
patrickperry
« Reply #8 on: 11 Mar 2007, 12:23 am »
you'll need burning software with any brand of burners.  If you buy benq new it is bundled with basic nero software which include nero's burning rom.  DVD shrink is freeware and there is a 21 days free trial with Anydvd.  So if you thinking about getting a new benq then you wouldn't need to purchase any additional software to start burning.  Just install nero, google and download dvd shrink, and then go to slysoft.com and download anydvd for the 21 days free trial.
There are numerous methods for ripping and burning dvd's but I think this is the easiest for someone starting out.
Fiji5555
« Reply #9 on: 11 Mar 2007, 12:28 am »
Go here and read a lot.....everything you need info wise is on this site.
http://forums.afterdawn.com/
