thinkin' on a tact 2.2 xp
0 Members and 1 Guest are viewing this topic. Read 4068 times.
2bigears
« on: 4 Mar 2007, 06:46 pm »
are these magic boxes worth the loot???? kickin' tires on a preamp,and this is a pre,with room correction,dual purpose unit??? any help thks. :D
zybar
Re: thinkin' on a tact 2.2 xp
« Reply #1 on: 4 Mar 2007, 06:53 pm »
When upgraded/modified by Anthony Aberdeen they can become world class!   aa
Without mods, it really depends on how poorly your room is setup and what amount of acoustical treatments you have present.
George
2bigears
« Reply #2 on: 4 Mar 2007, 07:41 pm »
thks,what is the mods worth????  my room sucks bad.need bass traps in the worst way. :D
jhm731
« Reply #3 on: 4 Mar 2007, 07:57 pm »
If your room suck, suggest you check out realtraps.com.
2bigears
« Reply #4 on: 4 Mar 2007, 08:22 pm »
that's it,one way or the other.a small basic trap kit is around 3k at your door.here with a Tact you get a pre amp with room correction????? :D :) :D
jhm731
« Reply #5 on: 4 Mar 2007, 08:34 pm »
You could get six 2' x 4' mini traps for the front & back corners and two for the reflection points for $1200, plus shipping.
If you have dual corner loaded subs or are planning to get them, then the TacT 2.2XP would be a good investment.
zybar
« Reply #6 on: 4 Mar 2007, 08:36 pm »
With the Tact, you can get preamp, dac, crossover, and room correction features depending on how the unit is configured.
However, I strongly suggest that you add some room treatments before going with ANY form of room correction.
Room correction can be a powerful tool, but it can't bend or break the laws of physics.
Concentrating on speaker/listen placement and room treatments first, will allow room correction to strut its stuff and allow you to really optimize your system.
George
2bigears
« Reply #7 on: 4 Mar 2007, 08:46 pm »
gotcha,realtraps first.tact later down the road...thks :D
