March Issue Affordable$$Audio
0 Members and 1 Guest are viewing this topic. Read 4208 times.
Affordable$$Audio
« on: 1 Mar 2007, 07:40 pm »
Affordable$$Audio's March issue is available for free download at:
www.affordableaudio.org
Thanks for reading!
JohnR
Re: March Issue Affordable$$Audio
« Reply #1 on: 1 Mar 2007, 08:29 pm »
Cool. Downloading it to read on the plane :thumb:
[Or not :( the connection at PHL is very slow ]
JohnR
« Reply #2 on: 1 Mar 2007, 08:50 pm »
Done! Better run to my gate  :o
Eric
« Reply #3 on: 3 Mar 2007, 12:07 am »
I keep getting an error when I attempt to open it. What might the issue be?
Affordable$$Audio
« Reply #4 on: 3 Mar 2007, 01:56 am »
First, do you have Adobe Acrobat Reader installed (latest version)?
If so, try this direct link, www.affordableaudio.org/aa2007-03.pdf
Eric
« Reply #5 on: 6 Mar 2007, 02:19 pm »
Yup, I have 7.0, but I'll try the direct link
Eric
« Reply #6 on: 6 Mar 2007, 02:20 pm »
Tried the direct link. Here is the error I am getting
Forbidden
Remote Host: [24.179.214.44]
You do not have permission to access http://www.affordableaudio.org/aa2007-03.pdf
Data files must be stored on the same site they are linked from.
Thank you for using FreeServers
Affordable$$Audio
« Reply #7 on: 6 Mar 2007, 04:39 pm »
Eric:
I just tried it at work on IE 6, works just fine.  if you have Firefox you can try downloading it with that browser.  or, if your email can handle a 10 meg file I'll be happy to send it to you directly.  Just pm me your email.
Mark
Charivari
« Reply #8 on: 7 Mar 2007, 05:29 am »
From what I've seen, the Affordable$$Audio host does not allow direct linking of files. However, if one's already viewed the file and it's in the browser's cache, then the direct link will work. It confused me at first too.
Btw, the Portland gathering information link needs fixing on the A$$A site.
- JP
Eric
« Reply #9 on: 7 Mar 2007, 06:06 pm »
Eric:
Mark
Mark,
I sent you a PM with my email
Eric
