System Design Goals
0 Members and 1 Guest are viewing this topic. Read 1828 times.
Daygloworange
  • www.customconcepts.ca
Re: System Design Goals
« Reply #20 on: 1 Mar 2007, 12:00 am »
C'mon man, you guys ever heard of Spinal Tap? It's gotta go to 11!
Cheers  :drums:
TONEPUB
« Reply #21 on: 4 Mar 2007, 03:44 am »
My main system is what I use to evaluate most of the gear that I review, so
there I am trying for as wide of a frequency response as I can get, Big dynamic
range and a lot of resolution without sacrificing musicality.
Because this system is my reference, I tried to assemble a system full of components
that would have more resolution than most of the gear I would review, so I could
easily tell the difference between review components.
My second system is a SET setup that is strictly for fun.  Nothing accurate about
it, but very enjoyable to listen to, and if you are an SET person, you know what
Im talking about.
Third system is my budget (or at least more reasonable) system, that consists
of gear that I think is representative of what the average audiophile owns.
I'm constantly tweeking this system to find the best "bang for the buck" components...
And next to my bed I have a SB3, Channel Islands Headphone amp and a pair of Sennheiser
HD 650's!
