AOL users that can't sign up to AC, read this...
0 Members and 1 Guest are viewing this topic. Read 2101 times.
TONEPUB
« on: 27 Feb 2007, 04:11 am »
Hi there:
We've had a few notes from AOL users that are having a bit of trouble registering.  Here is some info form the main admin board that might help...
Thanks for your patience!
First off, if you have just registered but cannot log in, it is most likely because you have not received or followed the instructions in your activation email. Please check your mailbox. If you don't get any email within a couple of hours, try resending your activation email.
For those used to the old restrictions on email addresses, these have mostly been removed.
If you have forgotten your email address or password, but remember at last one of them, then please use the Password reminder form.
If you have tried all of the above and have not received an email, then it is possible that your ISP is blocking our server email. If you post a request here, we can probably activate your account anyway. However, you will not be able to receive notification email from our server, so our first recommendation is to try another email address.
If nothing else works, then post a new topic here with as much information as you can provide, including the username that you registered with, and the email that you used when registering. Without this information, we can't do anything!!!
Note: make sure that you start a new topic with your specific issue. If you just tack onto an existing topic, there is a good chance that your request will be missed.
vinyl anachronist
    • The Vinyl Anachronist
Re: AOL users that can't sign up to AC, read this...
« Reply #1 on: 28 Feb 2007, 10:13 pm »
Ah, so that's what happened!
