0 Members and 1 Guest are viewing this topic. Read 9028 times.
For Occam and DAJ: A most common technique of reducing the effect of inductance in a capacitor is to bypass the cap with a smaller non/much lower inductive cap. Why pay big bucks for Auricap when you can bypass? d.b.
....Typical industry practice is to use multiple different value capacitors to spread the attenuation spectrum. I've found that a triplet of .47, .1 and .01uf low cost X2 rated caps (used in concert with inductive components) can equal the performance of a single .47uf Auricap in the same circuit. While that makes tremendous sense from a manufacturer's perspective, for a DIYer, doing a oneoff, dunno.......
Quote from: Dan Banquer on 6 Mar 2007, 12:18 pmFor Occam and DAJ: A most common technique of reducing the effect of inductance in a capacitor is to bypass the cap with a smaller non/much lower inductive cap. Why pay big bucks for Auricap when you can bypass? d.b.From my second post in this thread -Quote from: Occam on 28 Feb 2007, 06:19 pm....Typical industry practice is to use multiple different value capacitors to spread the attenuation spectrum. I've found that a triplet of .47, .1 and .01uf low cost X2 rated caps (used in concert with inductive components) can equal the performance of a single .47uf Auricap in the same circuit. While that makes tremendous sense from a manufacturer's perspective, for a DIYer, doing a oneoff, dunno.......Ummmm....Thanks? for the suggestion. My writing is admittedly a bit dense.
Hey Dan,A missreading of a dense text is well worth the the favor you did me in real measurements of an old project. Often, an empirical smack upside the head is a great prompt to revisit some equations one took for granted. Recently, I've actually gotten access to both a 20mHz LCR bridge as well as an HP network analyzer, and I'm happy to report the high 'Q' resonance is gone with the realization that throwing more capacitance at the problem, without the appropriate inductance isn't worth it. And even with various damping networks possible, I hate to admit that for practical reasons (actually knowing the load), ideally,[but not necessarily practically, for marketing reasons] the conditioning is best integrated into the component. That being said, the typical Corcoms and the like available to us can certainly be substantially bettered.Regards,PaulTo everyone else who doesn't manufacture their own components, I still advocate the use of an appropriate external power conditioner, if mains conditions call for it.
This will definitely show my ignorance on the subject , but is it possible to measure or see such resonances with an o-scope? If not, how about a spectral analyzer with FFT capabilities? It might be useful to sketch out a layman's understanding of how one would go about looking for such resonances. Thanks,
