Introducing Mark & Daniel Loudspeakers @ TweekGeek.com
0 Members and 1 Guest are viewing this topic. Read 2175 times.
cryotweaks
  • Funny name. Serious audio.
    • TweekGeek.com
TweekGeek.com is proud to announce the new line of loudspeakers from Mark and Daniel.
What I like about the Mark & Daniel loudspeakers
Well, for one the sound. Simply put, you will not believe the tansparency, speed, coherance, and sheer amount of sound that eminates from the Ruby and (especially the) Maximus monitors. Unique and very advanced driver technology, like high excursion woofers with Neodymium magnets that keep the voice coil in the magnetic gap throughout the entire range of it's excursion. Giving you high output, low distortion bass at full volume. You simply won't believe a speaker this small can hit hard at 40 Hz and not even break a sweat. But they do. Wide dispersion Heil Air Motion HF drivers that are crossed as low as 800 Hz presenting a huge, dynamic cohesive and deep soundstage like nothing you have heard in this price range. I have always been a fan of a single wide bandwidth driver crossed well out of the 2kHz band (an area where our ears are particularly sensitive to distortion and phase), the SP Technology speakers do this very well, but for those of us who do not have the space for their loudspeakers the M&D loudspeakers are a perfect fit. There are other differences between them, but they are mainly a matter of preference. Sonically both are knockouts.
So what makes these speakers different from any other?
1) The High Frequency Drivers are extremely wide bandwidth covering 5 octaves ( 800Hz-22kHz), and having a radiating surface area 60 times greater than a 1" dome tweeter, yet only 20% of its weight. The DM-1 utilizes a 10 micron (0.0004") ultra-thin aluminium ribbon which is symmetrically folded into 52 micro elements, constituting a diaphragm area more than 60 times that of a 1" dome while its attendant mass is less than 20%. The diaphragm is then submerged into a magnetic loop comprised of 21 Neodymium-Iron-Baron (NeFeB) magnets. The module is housed in a 5mm thick cast iron/stainless steel casing for rigidity.
2) The Low Frequency drivers have extremely high, extremely linear excursion. The Super Xmax Drivers are small drivers with big bass output.
The end result is that Mark & Daniel SX woofers can move more than 3 times the amount of air compared to an ordinary bass driver of the same size.  Although other long-throw bass speaker designs can be found, the SX driver is one of the very few whose excursion in both directions is always entirely under complete magnetic control throughout this range of motion. Constant magnetic control, even at the extremes of the speaker cone's travel , produces a "tight" disciplined bass, with no unnatural overtones, and no muddiness. The sound is clean, coherent, and accurate to the original source recording, not a vague approximation.
M&D's patented SX technology also employs the expensive NdFeB magnet to ensure a very powerful and even magnetic field. A high-efficient ribbon copper voice coil is wound around a TIL fiberglass former that can withstand 250ºC. The ultra-large rubber surround is out of proportion for a driver of its size. The cone is tough compound paper and the frame is die-cast aluminium. As a final touch, the signal-carrying lead-out wires that run behind the cone are secured by being threading through rings of DuPont Matamax dampers, protecting them from vibration caused by the enormous firepower. What we have here is a super driver that delivers deeper undistorted bass at much higher levels with more than double the linear excursion and at least 7dB higher SLPs than conventional drivers of the same size.
3) The enclosures are cast out of a single piece of Material. To complete the speaker package, M&D opted for a conventional boxy enclosure made of a not so conventional material: compound artificial marble (CAM). It's polished to a glossy shine. This material is similar to DuPont's Corian, more than twice as dense as MDF and less easy to break than natural marble. The entire enclosure is one molded piece of art - no seams, no joints, no veneer. The compound marble skin is 12mm thick and backed by a 5mm MDF liner that's spray-painted white to give an overall strength equivalent of 30mm MDF. Do not underestimate this 5mm of MDF. It plays a vital part in conjuring the warmth and musicality that most exclusively stoned cabinets lack. The tweeter and bass compartments are completely independent and separate chambers, the former being very shallow and just deep enough to contain the DREAMS HF module. Both chambers are generously lined with 20mm thick polyfoam to further damp cabinet vibrations.
Unique drivers with leading edge technology and the special Compound Marble hand-crafted enclosures produce clarity of sound that simply must be heard to be believed. All major components are developed and crafted "in-house" for unparalleled performance.
From Mini Monitors to Floorstanders
A full-range product line of M&D® speakers is available for your selection at TweekGeek.com. The Muse series is a great choice for hi-end AV speaker applications. For hi-fi reproduction, many start with the the 5" Maximus- Ruby, or the 6.5" Maximus-Monitor (My personal favorite). The 8" versatile Aragorn sound system is a superb choice for demanding audiophiles, and the huge 10" Apollo sound systems can re-produce enough low-end bass to shake any listening room while providing stunning clarity and transparency to the upper end of the audio spectrum.
A Word About Amplification
The Mark & Daniel Monitors require high current amplification of at least 100 watts. Single ended triodes need not apply. No offense to them, its just that the M&D speakers are relatively inefficient. The Ruby is 82.5 dB at 1 watt, and the Maximus is 85 dB.
« Last Edit: 23 Feb 2007, 02:59 am by cryotweaks »
cryotweaks
    • TweekGeek.com
Re: Introducing Mark & Daniel Loudspeakers @ TweekGeek.com
« Reply #1 on: 27 Feb 2007, 02:48 am »
Posts from two audiophiles whom I have a great deal of respect for.  This is from a recent listening session that I brought a pair of Maximus monitors to.
http://www.audiocircle.com/index.php?topic=37662.msg337813;topicseen#new
JDarby - Stereomojo.com
    • Stereomojo.com
« Reply #2 on: 22 Mar 2007, 12:14 pm »
Hey TweakGeek,
What a great site! We at Stereomojo.com are looking forward to the very first review of the Mark & Daniel Maximus. The technology built into the speakers is very interesting. Can't wait to hear them!
bbchem
« Reply #3 on: 27 Apr 2007, 04:45 am »
:lol: Hello Everyone, I am the Peoples Stereo reviewer and hope to provide you with info that will help you get the best bang for your buck. I give unbiased opinions. Today I am giving you my review of the Mark-Daniels Ruby which six moons gave their Blue Moon award to. I am now the proud owner of these amazing ground breaking speakers. Lately, I have been in love with several single driver full range loudspeakers. Well I read the review in 6 moons and found that my new speaker would be a cross between an electrostatic speaker and and a Single Driver full range. Well I can now tell you that this speaker is like listening to a 6foot tall 3 foot wide three way dynamic speaker. The sounds coming from these are so beyond their size, but more important the quality of sound is as if it was a large pin point floorstanding monitor!! They have Bass that confuses the listener for their size. Their detail is superb. I have had Totem and Proac small monitors that sounded great for their purpose, but these transcend whats possible with today's technology. I had a Carver 1.5T 350wpc power amp that can go to 1500 wpc max. My problem is that due to the 83 sensitivity and my lust for loudness, My 15 AMP house fuse is blowing. I want to point out that the speakers never broke a sweat no matter how much power I put into them, in fact they sounded better the louder they played! This is the only negative. When you get the loud sound you need, these are the best sounding speakers for the price and size on earth. If all audiophiles heard these, MD would sell billions!! I love them and will try to find out how to avoid kicking out my 15 AMP circuit breaker. A++++  :thumb: :thumb: :green:
« Last Edit: 27 Apr 2007, 12:07 pm by bbchem »
