Polite and respectful cable question re break-in
0 Members and 1 Guest are viewing this topic. Read 12642 times.
Dan Banquer
Re: Polite and respectful cable question re break-in
« Reply #20 on: 15 Feb 2007, 07:00 pm »
Go DIY and it's alot cheaper than 200.00. Considering I have taught an investment banker how to solder and put a cable togther, I think you can do this too.
               d.b.
Pez
« Reply #21 on: 15 Feb 2007, 07:34 pm »
So tell me Pez; if call Belden, what do you think they might tell me?
OK good point asking the preacher if God exists is not the best way to get an unbiased response.
Look, for me I can hear a difference. I'm not going to argue with someone about what they hear.  I just find it I little tiresome, this talk about something that is so entirely subjective and can not be objectively summarized in any way that is helpful.  In all honesty what this topic ALWAYS comes down to is those who hear and those who measure.  Neither camp is right or wrong, but for some reason it always goes in that direction. As you pointed out Occams post was spot on. By changing some tubes, for those of us that roll, you can achieve almost limitless changes to your system. Maybe they would measure slightly one way or another, but those meausurements probably would not correlate with any meaningful real number crunching data.
geezer
« Reply #22 on: 15 Feb 2007, 08:28 pm »
I suspect a measure of placebo effect.
Pez
« Reply #23 on: 15 Feb 2007, 08:38 pm »
for the measurers or the hearers?  :lol:
geezer
« Reply #24 on: 15 Feb 2007, 09:02 pm »
I am both
Pez
« Reply #25 on: 15 Feb 2007, 09:17 pm »
Well in that case you're completely delusional.  :duh:
 :D
Ethan Winer
  • Audio expert
« Reply #26 on: 16 Feb 2007, 04:57 pm »
gooberdude:
> if it can be so easily heard, why can't it be measured?? ,<
That's the whole point. It cannot be "easily heard" at all. It's all placebo effect, expectation bias, and perhaps most important, comb filtering.
rollo:
> Now I get it.Just visited your web site.Its all about acoustic comb filtering. <
That's only part of the equation. My personal feeling is that in most cases it's simply the frailty of human hearing and perception. Nothing really changes or "burns in" over the course of time, it's just that we can't remember well enough what it really used to sound like. But comb filtering is very real, as I proved in my article. So in the few cases where someone really does hear a difference, and it's not just their perception, comb filtering is the cause of that difference.
> I would think in a room after treatment it would be easier yet to HEAR the differences <
You are absolutely correct! In a properly treated room it is much easier to hear a difference when a difference truly exists. And likewise much easier to tell when there's no difference at all. However, even with acoustic treatment, comb filtering still occurs because of the different arrival times from the left and right speakers to each ear. But then at least the additional comb filtering from early reflections is avoided, and that helps to clear up the sound enormously. It also improves the sound stage and greatly reduces the effect of positional changes as you lean forward and back or left and right. My own living room is very well treated, including absorption at all the first reflection points. Not just the side walls, but the floor (carpet) and ceiling too. This is one reason I'm so confident that my audio assessments are accurate. That, and being a professional musician and recording engineer for nearly 40 years! 8)
Pez:
> can you tell me if a set of speakers have a good soundstage using measurements? <
Of course! The test for that measures the frequency response on- and off-axis. The more the off-axis response varies from the on-axis response, the worse the sound stage will be. However, the most important way to improve imaging and sound stage is to have absorption at all the first reflection points (see above). Avoiding all early reflections does far more to improve imaging than anything else, even which speakers you use.
> Can you detect if a set of speakers or an amplifier has good imaging characteristics? <
Nothing in an amplifier affects imaging. Maybe if the response is so bad it starts rolling off well below 20 KHz that would affect imaging. But assuming the amplifier is basically competent, there's nothing it can or cannot do that will affect imaging.
> Hell can you even tell me what a speaker will sound like based solely on measurements with any sort of accuracy? <
Certainly! If a speaker has a flat response, and low distortion, and the off-axis response is not too different from the on-axis response, it will by definition sound good. The reason all loudspeakers sound different is because none of them have an accurate response, or low distortion, or an accurate off-axis response. So it's a perpetual situation of trade-offs and the lesser of two evils.
> I say "You can't measure it, you aren't measuring the right thing." <
Please tell us what the "right thing" is. And be as specific as possible!
acresm22
> I know no one likes to talk about it, but "aural perception" is a fickle thing. <
You nailed it.
Steve:
> Several years ago I sent two sets of cables to Bruno Putzeys ... not only was there no difference between the two cables, there simply wasn't any distortion beyond the residual distortion of the AP rig. <
Exactly.
> To my knowledge, it has yet to be proved that it can actually be heard or for that matter that there's anything to hear in the first place. <
That too.
> So I guess one can turn the question around and ask, if it can be so easily heard, why hasn't it been proved yet? <
And that's the final nail in the coffin. :)
--Ethan
gooberdude
« Reply #27 on: 16 Feb 2007, 05:15 pm »
I have a question for ethan too..    Ethan, your responses are always appreciated!
Your last post mentioned that amps don't affect imaging.   A few months back i switched amps, upgrading from a '92 Muse Model 100 to an '02 Belles 150A Hot Rod.   musicans now appear to the outer left and right of my speakes, behind my speaks, and fill-in the center image much more....there are no 'holes' in the soundstage anymore.    All i know is the only component I changed was the amp, so if figure the new amp has a LOT to do with this.  can my brain be tricking me??  is this a case of comb filtering or just an old amp compared to a modern one?
since i'm bald i'm not sure if comb filtering affects my room    :lol:
matt
Dan Banquer
« Reply #28 on: 16 Feb 2007, 05:48 pm »
matt
As I posted on another thread, when this subject came up, is that I have found that if the crosstalk between the channels is high enough and out of phase, this can be perceived as an Imaging/Soundstage problem. Those are my observations, and should be taken as that only.
               d.b.
miklorsmith
« Reply #29 on: 16 Feb 2007, 06:04 pm »
Re:  Distortion - the widest definition of this would be any deviation from the incoming signal to the output.  However, for obvious reasons distortion has to be broken down into types and measured as such.  When we are talking flat response and distortion being the two important ingredients to what sounds good, what parameters of distortion are we talking about?  Total Harmonic Distortion is bandied about, but what does this term actually mean and specifically what is measured to determine it?  Is this not a proper loudspeaker measurement, because I never see it related to loudspeakers.
Regarding imaging, what relationship does the off-axis response matter when imaging is anchored to the sweet spot?  Aren't there a lot of other factors, i.e. distance between speakers, distance between speakers and listener, room properties?  FWIW, electronics play a role as Dan has mused above, and with other elements from my experience.
On flat response in-room, I can do this with my TacT preamp.  Measured flat doesn't sound flat to the ears at any volume.  To me, TacT, and the other TacT users whose correction graphs I've seen tend to like a bump from 20 hz to about 100 hz and descending response above about 8 khz.  When I've sat and listened to test tones with my room corrected, I aim for what sounds flat to my ears and this is what I've found.  When I select the "flat" correction curve, I'm runnin' for the controls to get it fixed immediately.
Steve Eddy
    • http://www.q-audio.com
« Reply #30 on: 16 Feb 2007, 06:41 pm »
I wouldn't say that. It's just a question. As has been said, absence of proof is not proof of absence. So best we can say is that there is currently an abesnce of proof.
se
gooberdude
« Reply #31 on: 16 Feb 2007, 07:31 pm »
hey Steve Eddy,
have you noticed any burn-in on the cables you make??
Pez
« Reply #32 on: 16 Feb 2007, 09:22 pm »
Well said Steve.  Sort of reminds me a bit of the problems astrophysists have in explaining gravity, dark matter and dark energy.  They don't know what it is, how it works, or how to measure it, but they know it's there.
Ethan you're answers are not as accurate and well defined as you would like to think.  I have heard numerous speakers with horrible off axis meausurements have a wonderful soundstage. I've heard speakers with pretty much ruler flat response that sounded horrible and have all kinds of sonic abberations off-axis. And yes I have heard an amp image poorly that measures well. I'm not going to argue this any more as I doubt anything I say to you would mean any more than "a nail in a coffin" to you.  :roll:
Steve Eddy
« Reply #33 on: 16 Feb 2007, 09:44 pm »
Nothing to speak of, but then I'm not the typical fly specks audiophile type listener (and hope I never become one :green:)
se
Steve Eddy
« Reply #34 on: 16 Feb 2007, 09:50 pm »
Thanks. Though to be fair, in this case, and contrary to your astrophysics example, we don't know that it's there.
se
avahifi
    • http://www.avahifi.com
« Reply #35 on: 16 Feb 2007, 10:00 pm »
Oh dear you are all missing the REAL issue, which is not when the cable is broken in, but when the cable is broken!  Like when the cleaning lady ran over it with the vacuum cleaner, and twisted it into a nasty fuzzball and hid the remains behind the chair.  Spark, smoke, snap, stink.  What you need is stuff that will stand up to an Orick or Electrolux, not whimpy multi-strand stuff that breaks when it gets a few ohms across it.
Frank
gooberdude
« Reply #36 on: 16 Feb 2007, 10:12 pm »
This could be posted as a new thread....but are Cleaning Lady's the #1 threat to Audio in '07?
so many sad stories.
Steve Eddy
« Reply #37 on: 16 Feb 2007, 11:25 pm »
Er, "breaks when it gets a few ohms across it"? :scratch:
se
avahifi
« Reply #38 on: 17 Feb 2007, 12:35 am »
Or a few henries, especially if henry is a big cat that love to chew on cables   :)
Pez
« Reply #39 on: 17 Feb 2007, 12:42 am »
Hehe reminds me of "Christmas Vacation" I wonder what that would smell like. :scratch:
