fuse size for SE9?
0 Members and 1 Guest are viewing this topic. Read 3202 times.
superdow
fuse size for SE9?
« on: 10 Feb 2007, 08:39 pm »
anyone know what size fuse the norh se 9 takes.  225V 2 amp? quick blow
HarleyMYK
Re: fuse size for SE9?
« Reply #1 on: 20 Feb 2007, 01:10 am »
I have an American style (120V) and it has a 2 amp fuse.
bwp
« Reply #2 on: 21 Dec 2010, 03:37 am »
Just want to confirm, it takes a 2amp quick blow?  I am blowing fuses and need to investigate but want to make sure I have the correct fuse first and foremost.
bwp
« Reply #3 on: 21 Dec 2010, 04:01 pm »
Norh actually got back to me and said it uses a 3a 220v or 6a 110v.  Still not sure if quick blow or slow blow, waiting for a response to that question.
petrL
« Reply #4 on: 25 Dec 2010, 09:49 am »
Try slow blow, and if the problem persists, then you have - a problem*.
btw the SE-9 steadily takes only 0.5 amperes @ 230Volts.
* if it blows immediately after switch-on, the there is short in mains transformer (bad) or somewhere else in the heater circuit.
bwp
« Reply #5 on: 25 Dec 2010, 08:39 pm »
It is blowing a fuse about 5-10 seconds after turningit on. I am hoping it is a bad power tube, I have some on order. I have replaced the rectifier tube but that did not solve the problem.
petrL
« Reply #6 on: 26 Dec 2010, 05:25 pm »
Then it is probably in the high voltage (B+) circuit. Could be the power tube.
