First round of new Niagara Amplifiers Shipping
0 Members and 1 Guest are viewing this topic. Read 8026 times.
PaulHilgeman
« on: 10 Feb 2007, 12:33 am »
Thought I would snap some pictures, the new enclosures turned out incredibly, the quality is VERY high end:
Also lots of other gallery updates, so go browse!!!
Have a great weekend guys,
Paul
PaulHilgeman
Re: First round of new Niagara Amplifiers Shipping
« Reply #1 on: 11 Feb 2007, 09:46 pm »
Just to show the different front power switch options, here are two, amber and blue.  Green and Red are also available.
-Paul
DARTH AUDIO
« Reply #2 on: 11 Feb 2007, 10:21 pm »
Paul, going to try to make it to the Chicago Audio Society meeting on the 18th. Just wondering if you can bridge these amps into mono's??
Gary
PaulHilgeman
« Reply #3 on: 11 Feb 2007, 10:56 pm »
Sure, they certainly can be, but would require extra circuitry if not using a balanced signal.
The better and cheaper option would be to use the next level of Hypex amplifiers, the UcD700, which I am certainly happy to provide.
The reason I am hesitant to offer a bridgeable system like this is because each amp channel only sees half of the impedance of the speaker.  So, if your speaker dips to 3 ohms or so, each amp only sees 1.5 ohms.
Bridged UcD400's would struggle a bit here, but a single UcD700 would drive a 3 ohm load all day long.
If you are running 8 ohms, no problem at all, but the UcD700 would provide similar power at a lower cost.
-Paul
Russell Dawkins
« Reply #4 on: 12 Feb 2007, 06:09 pm »
Bullseye!
Congratulations, Paul, on the visual aesthetics of the design.
Very refined and understated yet conveying quality.
Many well financed manufacturers never get things this right.
The convenience of balanced/unbalanced inputs is nice, too.
220v version available?
PaulHilgeman
« Reply #5 on: 12 Feb 2007, 06:27 pm »
Yes, a 220V version is available and the first one will be shipping next week!
-Paul
P.S.  Thanks for the compliment!
DARTH AUDIO
« Reply #6 on: 12 Feb 2007, 07:53 pm »
Paul, thanks for the info. I look forward to meeting you next Sunday. What other equipment will you be using in your system? Preamp? Source? Cables?
Gary
DARTH AUDIO
« Reply #7 on: 12 Feb 2007, 07:55 pm »
BTW, nice review in Stereotimes.
http://www.stereotimes.com/
PaulHilgeman
« Reply #8 on: 12 Feb 2007, 09:15 pm »
Thanks about the review...
The source will be Ayre CX-7e
The preamp will be Ayre C5-xe
Cabling will be Furutech Evolution and reference series.
Speakers will be the passive Ronin and the Sentinel
-Paul
