0 Members and 2 Guests are viewing this topic. Read 52410 times.
i wonder if the metal brackets close to the magnets is affecting things? just kidding!!!
you really aren't that happy with them??
Are they grounded, felted & de-screen'd?
Mine work best pointed towards the sky - up, up & away...about a 40 degree angle in their baffles is good.
John,Is there a "rule of thumb" that you used to get the dims for your cddwg/rlh or was it just intuition? I ask because I wonder if anyone would be willing to do what you have done but with a different driver. I was thinking of the SI's. Huge, I know. I understand that you had abandoned using styrofoam since the fiberglass resonated too much, but what if someone were not averse to it being unfinished? If I were to laminate that stuff together and carve it into a solid sphere then cut out the wg apertures front and rear... What do you think? how big of a sphere would it need to be? 90deg opening front and rear or is it not constant? Perhaps a silly idea, but then why not?I am creeping into this OB thing very slowly. I just won and am soon to receive a pair of 12" Corals(not FR, alas) from eBay. Hooray. BTW, do you know if there exists the sort of software you are using as xover for Mac? Otherwise I will have to go with a Pro Xover like MJ's DBX or something to pair with my DEQ2496.This has been fun reading and seeing what you guys have been doing. Thanks for sharing with us lurkers.Erik
I can sit down next my new OB drivers for a full album, touching and groping for them vibes
Erik,Here's some stuff on waveguides http://sound.westhost.com/articles/waveguides1.htmBelieve me when I say you don't want to use styrofoam in a speaker. It transmits sound too well. Think how clearly you can hear ice sloshing around inside a styrofoam icechest. The stuff I made was with stuff just like a cheap icechest, polystyrene beads bonded into a sheet. The sheets like the blue stuff used in construction is probably much better, but it's not available down here. The problem I had was that sound hit the foam and travelled right through it, and pressing my ear to it was louder than the speaker. Fun but a complete waste of time. There's an audio reviewer who built a U-baffle type OB out of styrofoam and posted the details on the web a couple of years ago. Needless to say that he has lost all credibility with me.After some recent stuff I've done, I'm losing my faith in real wood too. For me it's about the same price as plywood, and finishing is so much easier (rub some oil on and you're done, except for rubbing more oil). The problem I'm finding is that wood transmits sound too well, so I'll end up having to laminate layers of other material to it for damping, and/or make driver mounting rings out of a dead material like MDF and decouple that from the baffle. That gives me the added benefit of quick easy changes in drivers, making my baffles more versatile even with flush mounting. Damping the driver frame will help some, but think about the sound directly hitting the driver cutout. That's only an inch or less away from the sound source. Think about how loud that is.... say 90db at 1m...+6db each halving of distance or about 120db ! Whatever portion that gets into the wood at the driver cutout travels throughout the baffle.Don't worry Bob, those Augies are playing frequencies way below the resonant frequency of your maple, plus it's butcher block.Not only do we have to listen to our OB's, but we need to feel them too for vibrations. Someone mentioned a good trick to me the other day. Put a screwdriver handle to your ear, and touch the other end to your baffle.
