I do have a 9-3 Viggen. It's a fun car. And useful to boot. (I chose my moniker not because I'm a car guy -- I'm not -- but because no one has this name anywhere.)
Quote from: lazydays on 6 Feb 2007, 05:16 pm1** once the engine has circulated the oil for three or four minutes (most of the manufacturers are specing 5w-30) the oil is right where it should be. If you happen to be using synthetics; there is no real difference between cold oil and hot oil.Yes, the engine oil, which still leaves the transmission fluid, the differential oil, and the grease in the various bearings.Quote2**that would be true in an older car built in the seventies or sixties. But all the newer ones sense the ambiant temp, as well as engine temp, and adjust from there. You can't change it as it's in the computor that runs the engine and fuel delivery system.Still true today. Try flooring the gas before the engine warms up to see how sluggish it is. When the engine is in warmup mode, power and efficiency go down the crapper, this is what it's supposed to do, as directed by the ECU for emmissions control reasons.Quote3**virtually all fuel injection systems have a gas return line back to the tank or fuel delivery line. You will never use anymore gas than needed because the CPU will not allow it. Still if you happen to have a bad sensor the fuel injection system will automaticly go into a full fuel delivery. Might want to have a scan run on the sensors.I think we have a mis-understanding here. The engine is essentially an air pump, it takes X units of air to make Y units of power. When it's cold the air is denser, thus X units of air will fit into a smaller volume, so to make the same amount of power, for say cruising on the highway, a smaller volume of air is needed. To do that, the throttle valve is choked back, which results in more engine vacuum and pumping losses since you're now sucking air in through a smaller tube.Quote4**torque convertors are set to lock up at speed above forty mph, unless the speed sensor is out of wack. It's pretty much a mechanical thing after that. In theory, and it also depends on the design of the darn thing. Some, like the one in my car don't lock up until the fluid is warm enough. Others have fuzzy logic which juggle speed, temperature, and a bunch of other parameters. Still others are strictly speed based.
O.K. guys, I've got a few questions on cars that someone might be able to help me with.1. Why does my car get poorer gas mileage in the winter?
Very true. Or they judge the mpg based on the useless trip computer Bob
Sorry guys if I'm a bit sceptical on using fuel blends as the reason for Dans decrease in economy. Working in the repair industry for the past couple decades, I'd be seeing hoards of people banging down my door if they noticed a 10mpg drop in efficiency. And that number is from a pretty fuel efficient vehicle, if it was the fuels fault, what would the Suburban, Excursion, Hummer owners be claiming for their mpg rating?
I also added about a half a tank of 89 Octane to the regular 87 Octane and this appears to help a bit, or I just could be fooling myself.So Bob; am I fooling myself? or does this help a bit in the cold weather?
Gary, if you're responsible for some of the engineering ideas out there, I've got some technicians that want to have a chat with you (in a dark alley) HA HA, sorry, just kidding Gary. Bob
Sorry guys if I'm a bit sceptical on using fuel blends as the reason for Dans decrease in economy. Working in the repair industry for the past couple decades, I'd be seeing hoards of people banging down my door if they noticed a 10mpg drop in efficiency. And that number is from a pretty fuel efficient vehicle, if it was the fuels fault, what would the Suburban, Excursion, Hummer owners be claiming for their mpg rating? Besides, I believe the EPA would intervene if this happened to too many people.By the way, I am the owner of a full size GM truck (5.3l) who's economy doesn't change by season.Bob
Quote from: Dan Banquer on 7 Feb 2007, 11:44 pmI also added about a half a tank of 89 Octane to the regular 87 Octane and this appears to help a bit, or I just could be fooling myself.So Bob; am I fooling myself? or does this help a bit in the cold weather?Dan -I wouldn't think it would make enough of a difference in your car to "save money". Your fuel delivery system is adaptive, so it would run a little more efficiently (better combustion process). But to justify the price per gallon, your not really gaining much.Just out of curiosity, when was the last time the injectors/valve train cleaned of carbon deposits?Keep us posted Dan!Bob
I don't think I have ever had the injectors or valves pulled out and manually cleaned.
I have used some fuel additives in the past that claimed that they would clean the carbon deposits but I am rather skeptical as it appeared that there was no increase in performance. My mechanic has told me flat out that these additives don't do diddly squat as there are plenty of additives in the fuel to take care of this.
I only use the 89 Octane when it's very cold, (single digit temps) seems to help a bit when starting the car, or is this my imagination? The car does seem to run a bit smoother in the cold with a touch higher Octane mix.
