0 Members and 1 Guest are viewing this topic. Read 18130 times.
2. When the engine is cold, the fuel/air mix and spark timing isn't optimum so it's less efficient.3. Cold air is denser, which means the engine needs a smaller volume of it to provide a given power. Therefore the throttle valve will be open less than usual at any given cruising speed, this means more pumping losses for the engine since it now works harder to suck in air.
Dan what make/model/year vehicle do you have?Have you seen any malfunction indicator warning lights/messages?Good thinking about the air pressure. Suprised it took this long to see that.I've got more questions but need to know what kind of beast we're talking about first.Bobp.s. By the way, I smell a Saab 9.3 owner here.
In my car, which has a turbo, I get better mileage in the winter (as compared to other seasons where the AC isn't used -- the worst mileage is always with the AC on). The more dense air helps the gas mileage, and certainly helps power. Perhaps it's the opposite with non-turbo cars?
Several things actually.1. All the lubricating fluids in the car are thicker and less slippery which leads to more friction until everything warms up.2. When the engine is cold, the fuel/air mix and spark timing isn't optimum so it's less efficient.3. Cold air is denser, which means the engine needs a smaller volume of it to provide a given power. Therefore the throttle valve will be open less than usual at any given cruising speed, this means more pumping losses for the engine since it now works harder to suck in air.4. The locking torque convertor in an automatic transmission may not lock up until it's warms up sufficiently. This leads to the engine reving higher and suffering more frictional and pumping losses which kills efficiency.
Petroleum fueled engines use heat as the primary motive force (explosions of fuel in the cylinders causing expansion) so it seems reasonable that until the engine warms up, some of the heat and therefore expansion is lost. The cold weather of the last few days has reminded me of how stiff the automatic transmission fluid gets (validating what was mentioned above).
1** once the engine has circulated the oil for three or four minutes (most of the manufacturers are specing 5w-30) the oil is right where it should be. If you happen to be using synthetics; there is no real difference between cold oil and hot oil.
2**that would be true in an older car built in the seventies or sixties. But all the newer ones sense the ambiant temp, as well as engine temp, and adjust from there. You can't change it as it's in the computor that runs the engine and fuel delivery system.
3**virtually all fuel injection systems have a gas return line back to the tank or fuel delivery line. You will never use anymore gas than needed because the CPU will not allow it. Still if you happen to have a bad sensor the fuel injection system will automaticly go into a full fuel delivery. Might want to have a scan run on the sensors.
4**torque convertors are set to lock up at speed above forty mph, unless the speed sensor is out of wack. It's pretty much a mechanical thing after that.
