Response Seam -- how to mount (number of pins)
jmourik
« on: 6 Feb 2007, 12:10 am »
What is the best way to mount the response seams? How many pins should I use? Should the top and bottom be as flush as possible with ceiling/wall or should there be some space? Flush looks better.
4, one on each corner
5, one on each corner, one extra in ceiling in the middle OR one extra in the wall in the middle
6, one on each corner, one extra in ceiling and wall in the middle
Suggestions, please :-)
jan
8thnerve
Re: Response Seam -- how to mount (number of pins)
« Reply #1 on: 22 Feb 2007, 07:32 pm »
6 would be best if you don't mind all the pins.  4 works fine if you pull them nice and tight.  I usually end up with 5 to be honest. :-)  I hope that wasn't too non-committal!
Best Regards,
Nathan Loyer
Eighth Nerve
Rob Babcock
« Reply #2 on: 23 Feb 2007, 06:43 am »
Since I live alone I have no WAF issues I'll come right out and confess- I used a staple gun. :oops: :lol:
